No lube on 6-gear diff thrust bearing?
- flatspunout
- Has thanked: 7 times
- Been thanked: 4 times
I haven't rebuilt a 6-gear in three decades, so while going through my old one "by the book" I noticed the manual does not call for any lubrication on the diff thrust bearing or washers. Is that correct?? Surely it's an omission from the manual...I've never heard of such sorcery.
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2094 times
Re: No lube on 6-gear diff thrust bearing?
https://img2.associatedelectrics.com/pdf/cars_and_trucks/RC10_Classic/RC10_Classic_Kit/manual_RC10Classic_2013.pdf
For the thrust bearing, I use whatever general purpose grease I have handy, usually something for a fishing reel.
For the diff, whatever ball diff grease I have. The last couple I did, I used Tamiya ball diff grease on.
- flatspunout
Interesting that the re-re manual says to lube it while the original does not. The original manual also indicates grease should be used on the inner hub of the spur gear, I see that is omitted from the re-re version.
I’m tempted to believe the guys who designed the car as opposed to whoever wrote the new manual.
- juicedcoupe
It might be a difference in materials used in the original vs the re-re.
If the cage for the original thrust bearing was a self-lubricating material, they might not have felt it necessary to grease it. And since it was designed as a race car, routine maintenance and inspection would be expected.
- radioactivity
- Has thanked: 384 times
- Been thanked: 618 times
flatspunout
rc10resto found an excerpt from the original manual.
"The following copied from AE RC10 Classic Manual:
VariLok Diff Adjustment Tips:
Be sure to only use Associated diff lube #6636, and apply a small
amount on both sides of the diff balls. Do not use this diff grease
anywhere else on the vehicle! It is not intended as a lubricant (Use only
Associated diff lube as it has special additives to ensure the balls roll
instead of slide)."
I believe that the 6636 lube has some "grit" to it that makes it quite different than other lubes.
Chuck
instead of slide)."
Chuck
- juicedcoupe
6636 is pretty much the same thing as every ball diff grease out there. It allows the balls to turn freely in the gear, while reducing slip between the balls and rings.
And the original RC10 used an on-road style differential, which is why they say to use their "on-road" grease.
The thrust bearing should get a moly grease. The diff balls should have a silicone based lubricant. No matter the brand of diff. Never run them dry.
- flatspunout
Just for clarity, that's step 74 from the original manual and it is referring to the spur gear balls, not the diff thrust bearing balls.radioactivity wrote: ↑Wed Jul 14, 2021 6:07 pm flatspunout
instead of slide)."
Chuck
- jcwrks
- Has thanked: 171 times
- Been thanked: 393 times
As pointed out above the og manual doesn't state that you need to put any grease on the thrust. I never used any bitd , nor did any racers I know. It's also worth noting that the Losi hydradrive used a similar thrust that was exposed, and it too did not require grease.
The TX SKUNK
- Bottom Feeder
- Has thanked: 13 times
- Been thanked: 25 times
True, but just like the gears, just because it doesn't state it requires lubrication doesn't mean it wouldn't benefit from using some of the correct type.jcwrks wrote: ↑Thu Jul 15, 2021 11:34 amAs pointed out above the og manual doesn't state that you need to put any grease on the thrust. I never used any bitd , nor did any racers I know. It's also worth noting that the Losi hydradrive used a similar thrust that was exposed, and it too did not require grease.
- Has thanked: 1129 times
- Been thanked: 3917 times
I ran my 6 gears thrust dry back in the day simply from not knowing better. These days I definitely would. Excess will fling off anyway so just a super light coating is all it needs.
As a side note, our power clutch thrust called for grease.
- Been thanked: 7 times
I've found that the original manual is much better in telling you how to get the diff set up properly. I followed the original manual and my diff performs much better
- 1150 Views
Last post by mytimac
- 990 Views
Last post by CTYankee
- 1383 Views
Last post by JosephS
- 2435 Views
Last post by 85Edinger
- 1010 Views
Last post by Tamlok
- 895 Views
Last post by sandkil
- 1969 Views
Last post by adam lancia
- 887 Views
Last post by aconsola
Users browsing this forum: Bing [Bot] and 5 guests
