were there v2 10mm shocks?
General info, Q&A.
JosephS
Has thanked: 1243 times
Been thanked: 639 times
Post by JosephS »
Has thanked: 269 times
Been thanked: 2094 times
Re: were there v2 10mm shocks?
Yes. There were small bore V2 shocks, with and without threaded bodies.
JosephS
Post by JosephS »
juicedcoupe wrote: Tue Jun 22, 2021 1:58 am Yes. There were small bore V2 shocks, with and without threaded bodies.
Thanks for that. I think my current build is actually using the small bore v2. I’m going to wager that the v1 is close enough in performance.
Yes v1 and v2 are essentially the same. The seal end is changed slightly from the first bottom load to top load to bottom load with a cap. The seal is the same just held in place differently. The threaded bodies helped ride height setting tuning.
JosephS
Post by JosephS »
jwscab wrote: Tue Jun 22, 2021 12:07 pm Yes v1 and v2 are essentially the same. The seal end is changed slightly from the first bottom load to top load to bottom load with a cap. The seal is the same just held in place differently. The threaded bodies helped ride height setting tuning.
That is going to greatly simplify my build. I'll use what I have and get the right springs.
The Associated Enduro shocks look an awful lot like v2 10mm threaded shocks. I wonder if the rebuild kit will work.
Users browsing this forum: No User AvatarTbot [Bot] and 3 guests
