Apologies if this has been discussed, search didn't warrant much relevant.... what is the consensus on filling shocks for a shelf car? I have a build in mind with vintage unassembled shocks, and I'm thinking to just use a little bit of shock oil during assembly just to lubricate the o-rings, but not to actually fill the shock... does that make sense, or is there long terms adverse effects I'm not thinking of? I'd rather not have leaks if not necessary. Thanks for any input!
-J
To oil a shelfer?
- Has thanked: 1243 times
- Been thanked: 639 times
Re: To oil a shelfer?
If they are top loading shocks, why not build them without gaskets? There isn't anything to hold in if you don't put oil them. You can then store the gaskets in a sealed bag to prevent them from drying out.jkranz wrote: ↑Wed Jun 02, 2021 12:29 pm Apologies if this has been discussed, search didn't warrant much relevant.... what is the consensus on filling shocks for a shelf car? I have a build in mind with vintage unassembled shocks, and I'm thinking to just use a little bit of shock oil during assembly just to lubricate the o-rings, but not to actually fill the shock... does that make sense, or is there long terms adverse effects I'm not thinking of? I'd rather not have leaks if not necessary. Thanks for any input!
-J
If I know I'm not using the car I still use green slime and a few drops necessary to assemble the shocks, but I don't fill them. This way they stay lubricated and if I change my mind it's just a fill and bleed and off we go.
- 1435 Views
Last post by marlo
- 23 Replies
- 2063 Views
Last post by jon burrows
- 1261 Views
Last post by yellabelly
- 849 Views
Last post by klavy69
- 1314 Views
Last post by janaya
- 23 Replies
- 2978 Views
Last post by RC10th
- 833 Views
Last post by RCveteran
- 715 Views
Last post by LTO_Dave
Users browsing this forum: Facebook [Bot] and 4 guests
