Losi JrxT rebuild
Budki
Has thanked: 4 times
Losi JrxT rebuild
Post by Budki »
I just finished tearing down a JrxT I recently purchased. It is mostly there.
The shock clamps were cracked so I made 3d printed ones for now.
It didn't have wheels. I could use some help finding rear wheels. I have a set of white disk wheels coming. Also need to find tires.
Not sure how to add pictures from my phone.
Has thanked: 3470 times
Been thanked: 1901 times
Re: Losi JrxT rebuild
Before you hit submit on your post there is an attachment option when you scroll down a little from the frame for the text. When you hit "attachments" you'll get different options depending on the OS of your phone. Then you just select the files you want. They have to be a certain size. < 2.75mb I think, but I'm not sure. If you get an error that they are too large you can either resize them or text them to yourself and save the received attachment. The saved attachment usually ends up being a much smaller file size than the original.
Budki
Post by Budki »
Ty, I'll give that a try.
Budki
Post by Budki »
Some of the parts so it can be dated. I belive this is an early version.
Budki
Post by Budki »
A couple of the parts I 3D printed. Clamps for the build (2 of the old ones are cracked. It has both thin and wide ones, so I designed both just in case. I also printed a battery cover, mostly just for cosmetics, as it doesn't hinge and the original one is gone so I just guessed at sizes from pictures.
Well, I had walked away for the night but that motor is driving me crazy. It looks familiar, but I can't seem to place it. What is it please? Sorry, I can't help with much info. I built a JRX2 for a friend and built a JRX Pro for myself years ago (1990 maybe? Arachnophobia was on TV I remember clearly), but didn't really do much with either.
Budki
Post by Budki »
Motor says Pocket Rocket.
Ahh, yes thank you! A version of Twisters motors I think, but I'm usually wrong. That Tekin ESC is sweet too. They can be taken apart, cleaned and rewired too if you're careful. Great set of electronics all the way around. It should turn out great! 8)
matt1ptkn
Has thanked: 80 times
Been thanked: 133 times
Post by matt1ptkn »
I always enjoy following early Losi builds. Those 3d parts you made look great! I'm looking forward to future updates!
Matt
Budki
Post by Budki »
I was on hold until the POR 15 showed up. Now I am cleaning and prepping the metal parts.
Budki
Post by Budki »
I did learn that the bottom aluminum flat head screws are not standard, but had their heads cut down. I had ordered new aluminum screws but they stick up too high, so I put the original ones back in with a little black touch-up.
I have the rear-end on now.
Budki
Post by Budki »
Chassis together. Next to the shocks.
I was building this for my shelf, I have a body to paint but missing wheels/tires. Since starting this I acquired a Jrx2. I am planning on restoring the Jrx2 and keeping it, but do I sell the JrxT? I am not sure.....Anyway, the project will continue.
Budki
Post by Budki »
And I think I'm done for a bit.
I have a clear body and some custom decals on the way. But not sure how much I can do until I find proper wheels.
Here it is with the Jrx2 I just picked up.
Synergy
Has thanked: 127 times
Been thanked: 72 times
Post by Synergy »
Got to love a JRXT
The chassis would certainly be deemed early as it lacks the servo saver hole, I don’t know enough to give an opinion on the other components.
Here's my TC Showroom
Mark Westerfield
Has thanked: 14 times
Been thanked: 35 times
Post by Mark Westerfield »
I have a set of used wheels for your truck. I also wouldn't mind getting that Yellow #4 FM receiver crystal from that AM receiver.
Return to “Losi Forum”
