Dog Bone spring and spacer 6372 information
- Has thanked: 1013 times
- Been thanked: 472 times
Hello all,
I am looking for information on the dog bone spring and spacer ASC6372.
I am hoping to find out the general specifications of the parts so I can just order replacements
If anyone has one could they measure the spring
Length at rest
length fully compressed
Outer diameter
If anyone know the other specifications such as spring rate that would be awesome
For the bushing what is the
thickness
inner diameter
outer diameter
I am hoping to go to a generic site such as https://www.thespringstore.com to order some of these
Edit
found the information by measuring a NIP set
Spring information
.7 "
.2" compressed
Wire thickness .01” .3mm
Washer
od .24” 6.3mm
I’d.2” 3.3mm
Thickness .06” 1.6mm
Length at rest
Outer diameter
thickness
inner diameter
outer diameter
Edit
Spring information
.7 "
.2" compressed
Washer
od .24” 6.3mm
I’d.2” 3.3mm
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
Re: Dog Bone spring and spacer 6372 information
I made a post in your other thread about this.
Those fit like the originals, whereas the spring from a pen is too big around.
- klavy69
- Moderator
- Has thanked: 561 times
- Been thanked: 265 times
Depends on which ball point pen you use. There are tons of different sizes and have only ran across a few that were too big. But like Jwscab stated ball point pen springs work just fine if you find the right size. It was easy for us since the LHS had pens made up for the shop that worked perfectly
- juicedcoupe
I took the measurements from a new 6372 set and found these that match.
I was able to score an NIP 6372 set but I think I will get a set of these since I recall these springs being easy to lose. Thanks.juicedcoupe wrote: ↑Mon Apr 26, 2021 1:01 am I took the measurements from a new 6372 set and found these that match.
- Been thanked: 87 times
I don't have a RC10 with dog bones and springs to try this but was wondering if two red shock o-rings one in the outdrive and one in the axle would work without binding things up. Similar to the RC10GT RTR set up.
I can try that on my build. Part of the reason I am looking for the information is that I am making a personal spreadsheet that specs out all of the Asc part numbers as industry standard specifications.rctenracer wrote: ↑Tue Apr 27, 2021 6:56 am I don't have a RC10 with dog bones and springs to try this but was wondering if two red shock o-rings one in the outdrive and one in the axle would work without binding things up. Similar to the RC10GT RTR set up.
Stuff like nuts,bolts,bearings, bushings, e-clips, gears springs and spacers.
Most of the time the parts are readily available via a hobby site for less money; it keeps me busy and I am learning how to specify parts.
I just found out rc captured thrust bearings are used in gun smithing as roller bearings. That was when I was looking for 4-40 threaded titanium rod. It’s a bit like jumping from one Wikipedia article to the next.
Spring information
.7 “
.2” compressed
Washer od .24” 6.3mm
I’d.2” 3.3mm
.7 “
.2” compressed
I’d.2” 3.3mm
- 1438 Views
Last post by cautiousone
- 1842 Views
Last post by Mad Racer
- 2174 Views
Last post by THUNDERSTRIKE1
- 1402 Views
Last post by JK Racing
- 551 Views
Last post by vintage racer
- 362 Views
- 619 Views
Last post by galaxie292
- 1057 Views
Last post by Chris00gt
