Losi XX modern runner build
- Lavigna
- Has thanked: 1010 times
- Been thanked: 1271 times
I love my XX Kinwald Trinity buggy so much I really wanted to build another. I'm planning to build this up into a high end runner with real performance potential, and modern electronics. I am also considering using some parts from the current 22 line, such as shocks. This is still up for debate though.
I'm starting with a beautiful new Standard length Graphite chassis. I am excited to use these beautiful Rusti Designs CF pieces.
I am still deciding on which combination of rear arms and Trinity rear block to use. The older pre-CR arms are longer, and therefore can be used with the more narrow XXX Trinity rear block. Decisions...
My Photo Gallery --->https://www.rc10talk.com/viewtopic.php?f=77&t=38934
- Lavigna
Re: Losi XX modern runner build
The 2.61 (truck) transmission is built up using all new pieces. Upgrades include these beautiful polished MIP lightened outdrives, and an aluminum diff nut. I also spent a lot of time trying to polish the transmission case for a unique aesthetics appearance, but the change is minimal.
I can say this is easily the smoothest XX series diff I have ever built. I'm not entirely sure why.
- ELF-BMX
- Has thanked: 31 times
- Been thanked: 50 times
Looks like a great start! The diff nut, was that in a kit or separate? Also the diff gear, who makes that snd is it aluminum?
There is nothing more satisfying to me when building a car is when you get the diff perfect and shocks smooth
. I can sit there a spin it all day long
Looking forward to this bud!
- Has thanked: 17 times
- Been thanked: 14 times
I've been running my MIP Aluminum axles with Weed Whacker Line for over a week in my Super XXT at the Track. No issues and no wear on the Titanium Outdrives! I had to glue them with CA glue.
The Super XXT has a one lap Handicap against a Brushed 13T XXT at the track(my buddy runs his and I let him almost lap me.) I have a 22T Slipper coming. The Brushless motors have too much torque, even for the dual slipper cranked down.
- Lavigna
Well, I am trying to build this up so it's not just another XX buggy. I was looking at the beautiful Losi lightened motor plate, and thought it would be so cool if the milled lines went all the way through.
It was scary taking a dremel to a NIB MK1 lightened plate. I removed the little tab for the clutch cover and then sanded and smoothed all the stamped edges. I carefully cut out each milled line with a dremel, and then filed it smooth.
These plates have a clear anodizing finish. I polished that off on the back to bottom side. I'm still undecided if I'm going to polish the rest or re-anodized it.
I like how the milled lines are now visible on all sides and bottom. It sure wasn't easy work, and I was lucky I didn't have a single slip with the dremel. The second picture shows the motor plate straight from the bag.
- Been thanked: 325 times
That looks beautiful Lavigna! But would those holes now permit more dirt and crap to enter? Probably a non-issue if it's a shelfer.
- Lavigna
The modern cars have slotted motor plates and no gear covers, so I am not worried about it. It probably won't get run much anyways, lol.
- Lavigna
I removed the rest of the clear anodizing and polished it all up. I mounted it up to the transmission using the Factory Works motor centering kit. I think this works really well with the milled motor plate and MIP outdrives. They all share the same look of machined and minimal.
These are the Factory Works instructions.
- radioactivity
- Has thanked: 383 times
- Been thanked: 587 times
Really fine work on the motor plate, exceptional.
Can't wait to see this build unveil.
Chuck
Chuck
- Lavigna
^ Thanks!
I was planning to install the stock slipper components (below), but then I began looking at the modern 22 series pads and plates. They have much greater surface area, and they feature the machined cuts for more grip. They fit well with just a few small modifications. The newer slipper should be better suited for the power of brushless.
- Essejay
- Has thanked: 124 times
- Been thanked: 103 times
As usual an incredible building from Lavigna
Regarding the tranny, why do you use the truck tranny? To better suit the brushless power?
Have a nice week-end!
Essejay
Essejay
- Lavigna
Thanks Essajay! I am using the truck transmission because I had all the pieces already. I am trying to keep my shopping on this build to a minimum. Over the years I have gathered a lot of truck XXT parts. Also, Kinwald used to use the 2.6 transmission on his XX buggies, so it's a small nod to him.
I did the Kinwald mod to the front carriers and cut off the top tab. It now has a direct kingpin setup carried over from the XXT.
- Lavigna
In the theme of trying to make this a unique build, I decided to cut out the upper plate. I then cut some carbon fiber sheet to slot inside. I sealed it from the underside. Getting it all to fit by hand was a pain, but I'm happy with the result.
- Lavigna
I'm unsure how much I like it...
- 32 Replies
- 5011 Views
Last post by vintagercaddict
- 47 Replies
- 7438 Views
Last post by License2iLL
- 29 Replies
- 5003 Views
Last post by Cplus
- 43 Replies
- 7351 Views
Last post by Lavigna
- 4830 Views
- 2140 Views
Last post by philk
- 54 Replies
- 10891 Views
Last post by mikesofunny
- 30 Replies
- 4602 Views
Last post by JK Racing
