Yokomo WSC 93/94 Arms
Oozzee
Has thanked: 21 times
Post by Oozzee »
Can anyone advise or know if the WCS 93 came with the lightened arms or the solid arms, searching through the forum I am thinking that it may have been either ???
Photo credit to RC10th
cheers
2014-06-13 22.13.55-1.jpg (55.3 KiB) Viewed 1872 times
2015-01-07 15.31.01-1.jpg (53.28 KiB) Viewed 1872 times
The Dreaded 7 - 10 Split
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Re: Yokomo WSC 93/94 Arms
Post by RC10th »
Archived..... lol
Maybe something useful or telling?
I wouldn't know what was original on that car due to all the custom machining.
Dual
Has thanked: 131 times
Been thanked: 40 times
Post by Dual »
Hey mate,
The Yokomo 1993 WCS production model came with the solid arms. Same versions that came standard on the 1994 YZ10.
Vin
Oozzee
Post by Oozzee »
ok good news then, thanks for the heads up,
also have you ever seen this type of rear bulkhead on a WCS
cheers
Dual
Post by Dual »
Oozzee wrote: Thu Mar 04, 2021 2:27 pm ok good news then, thanks for the heads up,
cheers
Very nice :wink: I have seen similar modifications performed on mag/alu bulkheads in the past. The machining work on the bulkhead on your WCS looks very well executed.
RC10th
Post by RC10th »
I wonder who modified your bulkhead as mine has been machined as well. Are there other machined touches to your car?
Oozzee
Post by Oozzee »
I will have a look at it again tonight mate and post up some more photos, from my amateur eye it looks stock except for the bulk head
do you have a photo of your bulkhead ??
pedro
Been thanked: 77 times
Post by pedro »
All the arms i've seen for this model are slightly different from the later yz10 in that they don't have the letters L and R molded into them and they also don't have the small (about 4mm) hole in them up near the bulkhead end of the arm.
Peter
RC10th
Post by RC10th »
Oozzee wrote: Sun Mar 07, 2021 2:26 pm I will have a look at it again tonight mate and post up some more photos, from my amateur eye it looks stock except for the bulk head
Dual
Post by Dual »
pedro wrote: Wed Mar 10, 2021 6:30 am All the arms i've seen for this model are slightly different from the later yz10 in that they don't have the letters L and R molded into them and they also don't have the small (about 4mm) hole in them up near the bulkhead end of the arm.
Peter
Great attention to detail Peter. I never noticed this and had to check my own NIB and new built versions. True enough, no L and R markings nor the small hole near the inside of the arm. Cheers.
Return to “Yokomo Forum”
