SR315 LED Power Source
Ralph68
Has thanked: 6 times
Post by Ralph68 »
I've got the DX3 w/SR315 setup.
Aux1 is being used by a cooling fan on the motor heat-sync.
I have added 2 white and 2 red leds for front and rear lights. I'm not sure where to safely grab the power from?
My options are:
1. Y split Aux1
2. Grab power from the Batt plug on the Rx.
3. Buy a SR515
like I said I'm not sure the best way to do this. I know the LED lights are 5v but I'm not sure what the fan is drawing?
I don't want to burn out anything pulling to much power from a single plug, maybe someone that has done this before can help me out?
coxbros1
Has thanked: 2758 times
Been thanked: 2407 times
Re: SR315 LED Power Source
Post by coxbros1 »
Using the Y should be ok....depends on what esc u have and how many amps the bec in is.
matt1ptkn
Has thanked: 80 times
Been thanked: 133 times
Post by matt1ptkn »
I agree. The LEDs won't pull very much current at all, so you should be fine with any of those options.
Matt
Ralph68
Post by Ralph68 »
I'm using the ARRMA BLX100 ESC.
BEC Voltage 6V
BEC Current 4A
https://www.arrma-rc.com/part/AR390069
Thanks for the reply!
coxbros1
Post by coxbros1 »
yep the "Y" will work with that unit
The LED's don't draw much. No worries pretty much any path you take. Are the LED's designed to drop in, ie. do they have a built in resistor?
Ralph68
Post by Ralph68 »
No resistor on the lights, they're a cheapo setup I got off ebay.
I want this setup correctly if I need one let me know I'll add it.
https://www.ebay.com/itm/1-10-1-8-Upgrade-4-LED-Light-Set-Headlight-Taillight-for-HSP-RC-Cars-US/254375421227?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Yes those have resistors. You can see the little lumps in the heat shrink near the leds. Be sure to keep them intact.
Ralph68
Post by Ralph68 »
Thanks very much for the help I really dislike going at this stuff totally blind so please know I appreciate the reply.
Here's a thought I just had.. Can I run the cooling fan off the Batt plug?
This would free up chnl 3 (Aux1) to use for lights?
Usually they have a nice heavy trace connecting all the power pins so that should be fine.
