"Chew Toy" recommendations
HS-YZ250
Has thanked: 178 times
Been thanked: 155 times
Post by HS-YZ250 »
This past weekend I took my Rocky Project for a spin on the re-purposed tennis court that serves as my girlfriend's neighborhood dog park, while her dog was with is. Immediately found that her dog finds the car a threat and/or a chase opportunity. I was able to duck and dodge despite being in tears laughing, but she eventually caught it and chomped the body pretty good while sending it into a fence. The body wasn't painted, yet, fortunately, and the car survived with little more than a derailed chain (got another body on order from bluegroove).
Now, my girlfriend wants this to be a regular way to exercise her dog, yet I don't want to sacrifice this Rocky I've slowly pieced together and just got running for this. So I'm soliciting ideas for a chassis to buy as a "chew toy."
I was thinking an older, shaft drive 4wd racer I could put sway bars and hard surface tires on, but with parts still available. The idea is something I can dart around with (that rocky mono-shock front end did it no favors), and really power away.
Would like to be under $200 if at all possible, but an initial search suggests a 4wd racer like a Lazer ZX 5,6,7, or an Associated B44-something, but those seem to be a lot of money still.
Ideas?
Losi LXT (JRX-T Conversion)
Losi JRX Pro SE
Kyosho Rocky
Parts-Car-to-Runner Kyosho Rocky
Yokomo YZ10 WCS '95 Pavidis
RJ Speed Spec10 "Chew Toy Mk1"
Redcat Lightning STK "Chew Toy Mk 2"
Kyosho Lazer ZX, ZX-R, ZX-RR
LowClassCC
Has thanked: 108 times
Been thanked: 171 times
Re: "Chew Toy" recommendations
Post by LowClassCC »
RJ Speed Legends car?
Cheap, very basic, easy to work on, not much there to get damaged.
http://www.rjspeed.com/kits/Legends/2010.html
Has thanked: 268 times
Been thanked: 2094 times
I use one of my Diggers to chase my great dane. It's tough as nails and he can't really get ahold of the beetle body.
HS-YZ250
Post by HS-YZ250 »
Is the Digger the old Bolink/RJ Speed? Do they handle pretty quickly?
Losi JRX Pro SE
Kyosho Rocky
LowClassCC
HS-YZ250 wrote: Mon Feb 08, 2021 10:08 pm Is the Digger the old Bolink/RJ Speed? Do they handle pretty quickly?
Yes. The only reason I mentioned the Legends and not the Digger was concern over the battery mounting position.
LowClassCC wrote: Mon Feb 08, 2021 10:51 pm
I actually prefer the bottom load battery, with the large o rings.
They are fun, fairly nimble little cars. Don't misunderstand it, they don't handle like a touring car.
They have foam tires and no suspension. They do tend to skip and bounce some. And being rear motor, they tend wheelie a lot too.
But one of the best things about them and the Legends cars is that most of the replacement parts are cheap, if you need something.
How can you go wrong with something this simple?
RC10resto
Has thanked: 1487 times
Been thanked: 550 times
Post by RC10resto »
Anything Traxxass :P
Dadio
Has thanked: 2757 times
Been thanked: 2250 times
Post by Dadio »
I've had this discussion on other forums , to me its a bad idea , not for the car but the dog , a torn lexan body could cut up a dogs mouth badly , if its fast and big enough to survive then it could injure the dogs legs if they collided , we have three dogs and I know that our Border Collie would go bonkers for it but I just can't see it as safe for the dog . just my humble opinion sorry .
HS-YZ250
Post by HS-YZ250 »
Dadio wrote: Tue Feb 09, 2021 6:09 am I've had this discussion on other forums , to me its a bad idea , not for the car but the dog , a torn lexan body could cut up a dogs mouth badly , if its fast and big enough to survive then it could injure the dogs legs if they collided , we have three dogs and I know that our Border Collie would go bonkers for it but I just can't see it as safe for the dog . just my humble opinion sorry .
This might sound callous, but this dog won't care. Seriously. She's a 70lb pit mix that ROUTINELY bloodies herself, and just plays through. Once, at a dog park, she smacked her head against a rock hard enough, while wrestling, that the dozen people nearby all groaned and winced because it was pretty obvious and sickening sound. But then she rocketed off with the pack, leaving onlookers stunned.
It's funny because she's super sensitive about my girlfriend hand trimming her claws, but wore her claws down until they bled chasing after my rocky, then kept playing with the neighbor's dog for another half hour.
I'll definitely re-evaluate if/when we try it again, though.
Also, I could always carve out a polyethylene foam block to act as a "Nerf" body.
Losi JRX Pro SE
Kyosho Rocky
HS-YZ250
Post by HS-YZ250 »
Looking at the Digger image, I do think I like the Legend for the battery mounting, also. Keep it contained in case she manages to get hold of it, again. Also, seems it'd be quicker handling; only reason the rocky didn't get destroyed aright away was being able to turn relatively fast, though I was cursing that monoshock front a couple of times.
Is RJ Speed still in Georgia? I remember Bolink was located at the end of Gwinette County Airport.
Losi JRX Pro SE
Kyosho Rocky
Maybe you should check out the WLToys 144001. It's a bit smaller of a buggy at 1:14 scale, but should be easily nimble enough to keep out of the dog's reach. I'm modding one here, if you want to follow the upgrade process.
https://www.rc10talk.com/viewtopic.php?f=114&t=45819
You can get these for under $100 USD and upgrade parts and entire parts sets are cheap. It comes with a brushed 550-size motor but a lot of people swap in their own electronics and turn them into brushless. The cheapness and availability of parts might be worth a consideration.
shodog
Been thanked: 91 times
Post by shodog »
Traxxas slash with a children’s stuffed animal ziptied to the top will make that dog go ape crap.
matt1ptkn
Has thanked: 80 times
Been thanked: 133 times
Post by matt1ptkn »
I was thinking an SCT of some sort, too. They have a large body that covers all the sensitive equipment (and sharp edges), they are easily tune-able and most are quite robust. Plus, cheap ones are all over the place. Nothing vintage about them at all, but they seem to fit the rest of the requirements.
Matt
coxbros1
Has thanked: 2758 times
Been thanked: 2407 times
Post by coxbros1 »
Lunchbox.....its a no brainer!
Users browsing this forum: No User AvatarBing [Bot] and 2 guests
