Quarter Flash Arm Mounts?
- Has thanked: 36 times
- Been thanked: 1319 times
I got 2 sets of rc10 arm mounts in a lot purchase. Unfortunately they were drilled out for bearings like the Quarter Flash arms. Has anyone ever seen the arm mounts done by them? I know I haven't. I also know doing this is not hard.... I've done it myself to a pair of arms years ago. So it doesn't have to be some manufacturers parts. Just some guy in basement.
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Quarter Flash Arm Mounts?
Never seen the arm mounts bored out. How did they do the back side without breaking them off the tree?
- KidAgain
- Business Member
- Has thanked: 513 times
- Been thanked: 432 times
Interesting I would like to see a complete package........... Never seen or heard of this mod.
There's a pic of some arms in this thread. They bore out the ends and installed 1/8 x 1/4 bearings for the hinge pin to ride on.
https://www.rc10talk.com/viewtopic.php?f=35&t=5232&p=49730
New in package arms in this thread. They made them for the 10t also.
https://www.rc10talk.com/viewtopic.php?f=35&t=24703
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
I'd heard the bearings had been from a slot car application so they should be easily found I would think.
This is all very interesting!
- Has thanked: 131 times
You can't rule out that they are 'home-made' but I am 99.9% sure they are Quarter Flash items. I have a set of the front and rear arm mounts on my Fibre-Lyte RC10. Definitely cool pieces but the stock arm mounts work just as well imo
The front arm mounts that I have needed to be massaged ever so slightly as the drilling process caused the edges to flare out and subsequently they were rubbing on the a-arms.
The bearings are tiny but like Al mentioned, they should be easy enough to find.
- 1193 Views
Last post by badhoopty
- 32 Replies
- 3579 Views
Last post by Dr. Robotnik
- 509 Views
- 1176 Views
Last post by longboardnj
- 1756 Views
Last post by templeofspeed
- 1008 Views
Last post by Superev1l
- 1241 Views
Last post by ELF-BMX
- 866 Views
