My special Optima Mid
blast
Has thanked: 116 times
Been thanked: 46 times
Post by blast »
Hello , at first this project was to build a runner from a stock Optima Mid i picked up from Ebay .
blast
Re: My special Optima Mid
Post by blast »
let's start with a complete disassembly
blast
Post by blast »
All parts cleaned and polished
I milled the stock chassis
blast
Post by blast »
I put the right screws on the wing mount
The buggy will be fully equipped with some optional parts that i already had.
Front universal shafts
Steel center gear (OT85) and rear ball diff
coxbros1
Has thanked: 2758 times
Been thanked: 2407 times
Post by coxbros1 »
Look'n good!
blast
Post by blast »
LiteSink motor plate, carbon fiber mounts and home made anti sway bar
Robinson Racing 48p main gear and Parma slip clutch system
blast
Post by blast »
Front ball diff
c/f mounts - anti sway bar
Robinson adjustable rear toe-in system
blast
Post by blast »
blast
Post by blast »
blast
Post by blast »
After polishing ... :)
Rc10 repro wing (trimed)
Optima Pro repro body
blast
Post by blast »
Tamiya PS49 sky blue , amazing color !
blast
Post by blast »
The aluminium chassis was not to my taste , luckily i found something unique to replace it
2nd strip down :roll: I took the opportunity to swap the ball diffs with gear diffs and install a new front bumper
blast
Post by blast »
Trinity Pure Gold 18x2
Completed !
As you can guess it's too clean to race , now the runner project turned into a winner contest :o (botm July 2020).
All comments or questions are welcome !
Beautiful build, blast! I really like your color choices for the paint, quite original! I see you mounted your LiteSink the same way I did with one of my builds, mounting it inboard instead of outboard. I think it's meant to be mounted outboard so the heatsink is outside the body where it will get some airflow. It's definitely cleaner mounted inboard, but you might have to consider that cooling ability will be reduced with almost no airflow passing over the heatsink when it's mounted inboard. I addressed that issue by cutting a hole in the front window and an exit hole at the back...at least if you'll be running it.
XLR8
Has thanked: 1684 times
Been thanked: 1180 times
Post by XLR8 »
Wow, what an awesome build! 8)
Thank you for posting it here.
It's great to see how this car came together. :wink:
Return to “Kyosho Forum”
