Chain Guides
HS-YZ250
Has thanked: 166 times
Been thanked: 153 times
Chain Guides
Post by HS-YZ250 »
Wanted to share something I've been over-thinking : mounting the electronics in this Rocky. The LeMans esc has two mounting screw holes on the bottom, which is also the heat sink. I want to use the mount and not adhere it, since it's shiny and nice looking, and I didn't want to put the heat sink against the ABS tub in case it got hot. Also, the tub only really has room where the original esc went, a bit off to the side and I thought the cables would bear against the body. So, I broke out my old Turbo Rocky chassis I got a while ago.
https://drive.google.com/file/d/1EqsvyQ6jOpl_9gaUyZlf1nLQI0LsjOQW/view?usp=drivesdk
I currently have the esc on a couple of existing holes, but that puts it up against the chain even without the chain guide, which I don't have and, from pictures, seems to be a different part than either of the standard Rocky guides, so I might have to 3D print one.
I could maybe drill anothet hole or two for the ESC, but I also don't like the cable tie mounting for the servo.
I'm considering this...
https://www.ebay.com/itm/Factory-Works-Racing-Chassis-set-for-Kyosho-Rocky-Lipo-Compatible-vtg-conversion-/303726180736
I'll still have to 3D print an upper chain guide, and maybe make a metal tab to mount the esc, but the kit seems to have the abs tub style servo mount. I'm just apprehensive about spending another $90 on this, though I already have full cv joints and a brushless system.
What would you guys do?
Losi LXT (JRX-T Conversion)
Losi JRX Pro SE
Kyosho Rocky
Parts-Car-to-Runner Kyosho Rocky
Yokomo YZ10 WCS '95 Pavidis
RJ Speed Spec10 "Chew Toy Mk1"
Redcat Lightning STK "Chew Toy Mk 2"
Kyosho Lazer ZX, ZX-R, ZX-RR
Has thanked: 1080 times
Been thanked: 3729 times
Re: Chain Guides
If you decide on the chassis from Factory Works, let me know as I can save you the ebay fees and ship direct to you.
to your actual question, I would not worry to much about mounting it to your tub. Modern speed controls do not require nearly the cooling that those of yesterday did.
coxbros1
Has thanked: 2654 times
Been thanked: 2310 times
Re: Chain Guides
Post by coxbros1 »
wish i had done that on those 834B parts i just bought....total bummer for sure
as far as the Rocky i would get the chassis for sure
HS-YZ250
Re: Chain Guides
Post by HS-YZ250 »
GoMachV wrote: Thu Oct 29, 2020 12:51 pm If you decide on the chassis from Factory Works, let me know as I can save you the ebay fees and ship direct to you.
I'll be in touch!
Losi JRX Pro SE
Kyosho Rocky
Return to “Kyosho Forum”
