CNC side work
- Has thanked: 11 times
- Been thanked: 6 times
CNC side work
Does anyone here do CNC work on the side ?
I have 2 Raco Roadrunner 1/4 Scale buggies that ned front shock towers.
1 is cracked , and the other buggy is missing them. I had the idea of have a set 3d printed , but I was told 3d printed towers wont be strong enough to handle a buggy that big.
I have searched Ebay for replacements , I cannot find any. Custom made towers is the next option if I can find someone that can make them for $$$.
- Has thanked: 1129 times
- Been thanked: 3919 times
- RC10resto
- Has thanked: 1487 times
- Been thanked: 550 times
- THEYTOOKMYTHUMB
- Has thanked: 3699 times
- Been thanked: 1980 times
Re: CNC side work
Sorry for the interruption, but this reminded of a comedian who said "Yeah, I mow lawns on the side. I pay another guy to do the front and back."
- XLR8
- Has thanked: 1684 times
- Been thanked: 1180 times
Re: CNC side work
I'm very generous with my lawn tools. I'll let anyone use my mower so long as it doesn't leave my yard.
... sorry, back to the subject...
Re: CNC side work
The original looks like plastic millled from a block. I've seen other guys make a simple version from thick plate aluminum. It has 2 mounting holes to mount to frame , 1 hole for shock mount screw, 1 bigger hole for roll cage tube to slide in to and 1 bigger hole for front axle tube to slide through.
It's the front shock towers for a raco jac rabbit/ Roadrunner.
( I'd post a picture but Photobucket has changed. I can no longer find the image code that I used to copy and paste )
Re: CNC side work
These are not my pictures. I found these on Google. Someone had made these replacements shock towers.
I believe the owner of the blue Raco is a member here.
I would like to have a set made like these but shaped a bit different so it's not a copy of someone else's work.
- KidAgain
- Business Member
- Has thanked: 513 times
- Been thanked: 431 times
Re: CNC side work
Maybe a carbon infused or pure carbon might hold up........................................
- Pyxster
Re: CNC side work
I think you'd be surprised on how strong 3D printed parts can be, especially the size of those pieces.
If that is printed with .3mm Layer heights, solid fill layers and a little hotter than normal, you can lookup CNC Kitchen on YouTube, he tests filaments and printing techniques
Problem is if that is out in the sun all day or in the trunk of a car, the plastic could soften some from the heat.
The actual material costs of those parts would probably be 50 cents and a couple hours of printing, so you can easily make spares cheaper than Aluminum, but they won't look as nice.
I made front arms for my HPI RS4 MT, they would last a long time unless I hit something stupid, and then it was just a couple minutes to swap it out. I also made a new front body mount.
- 1303 Views
Last post by fastang
- 1772 Views
- 945 Views
Last post by winner_evo
- 776 Views
Last post by DHood
- 28 Replies
- 2442 Views
Last post by obsidian
- 372 Views
- 685 Views
Last post by Brandon G
- 907 Views
Last post by Tadracket
Users browsing this forum: DotNetDotCom.org [Bot],
Mojeek [Bot] and 3 guests
