I have a really stupid question. I've searched the internet and came up with nothing. Probably because I myself don't even know how to ask what I want to ask.
Is there a " formula " or something used when figuring dimensions on a resized part ?
I basically want to build a 1/8 scale Tamiya Hornet, using a 3d printer. I have no idea on what size any parts need to be or how to figure it out.
1/10 scale to 1/8 scale
- Has thanked: 2759 times
- Been thanked: 2250 times
Re: 1/10 scale to 1/8 scale
Original part size multiplied by ten then divided by eight should do it . if you want to use 1/8 standard wheels then you will want to use a standard 1/8th hex drive ( don't know what that is ) not the Tamiya style drive flange , if your modeling up replica wheels then again adapt the size to fit a stock tire for 1/8th unless again you want to print tires as well .
- Been thanked: 325 times
I believe the answer to that question would be either 14mm hex or 17mm, with 17mm being far more common.
- 1849 Views
Last post by Drusky
- 778 Views
Last post by m_vice
- 1270 Views
Last post by adam lancia
- 19 Replies
- 2144 Views
Last post by myfordcnc
- 617 Views
Last post by tizeye
- 989 Views
Last post by purpletimbo
- 2331 Views
Last post by RC10th
- 1357 Views
Last post by Jay Dub
