3/16 CVA stub axle wiggle
sondeen
Been thanked: 9 times
Post by sondeen »
I recently picked up a vintage RC10 team car that was upgraded by prior owner to use the worlds re-re 3/16 CVD axle, with the re-re hub carrier and bearings. I noticed there was tremendous radial play (or wiggle) of the stub axle in the carrier. I could see that the stub axle to bearing fit was loose, as was the bearing to hub carrier fit. I disassembled the axle and the bearings fell out of the hub carrier they were so loose. The axle assembly looks almost new, with no obvious wear. Is this looseness typical in the worlds re-re??
My prior experience with vintage RC10s is all with the 1/4 axles, which have much less overall slop and the bearings fit tight into the hub carrier. The difference between my 1/4 axle cars and this car with 3/16 axles is drastic. Is it possible there are cheap knock-off copies of these re-re parts out there? I also swapped in a different pair of bearings that made no difference.
RC10 Graphite | RC10 Team Car | RC10 Graphite Team Car | RC10B3 | RC10 Edinger - Late | RC10 JG Monster Conversion | CAT XLS Masami | Optima Mid '87 WC ReRe | Original Ultima [sold]
Re: 3/16 CVA stub axle wiggle
The re-release hubs were known to be molded wrong. Too loose as you have seen .
sondeen
Post by sondeen »
Thanks for that info. Is there a common fix? I was thinking about loc-tightening the bearings in place, but that sounds like delicate surgery that could become a mess.
I should also note the prior owner did not use the crush tubes, could that also add to my problem?
jcwrks
Has thanked: 171 times
Been thanked: 393 times
Post by jcwrks »
Buy vintage AE hub carriers #6366
The TX SKUNK
