TECHNIGOLD
- coxbros1
- Has thanked: 2719 times
- Been thanked: 2373 times
TECHNIGOLD
Will Technipower brushes work in a Technigold? I have no experience with these, just got my 1st one, thanks
- coxbros1
- XLR8
- Has thanked: 1663 times
- Been thanked: 1171 times
Re: TECHNIGOLD
So you're asking if they will actually fit?
I have to admit that I also know very little about this but I did find this discussion, maybe you've already seen this:
https://www.tamiyaclub.com/forum/index.php?/topic/78337-differences-technipower-vs-technigold/
Considering how much in-depth is the analysis, if the brushes were so different that they could not be swapped between the two motors, they would have mentioned that. The discussion seems to center on performance differences.
Hope this helps or at least perhaps it will give you something to look at until an actual Tamiya motor expert chimes in.
- XLR8
Re: TECHNIGOLD
Also, I found this video:
and this in the comments:
"The brushes were different designs for the brush end for the technigold and techni motors but they are interchangeable. "
- coxbros1
- 1307 Views
Last post by Mr. ED
