Reversed decal question
- Has thanked: 9 times
- Been thanked: 5 times
Has anyone ever used the decals that are reversed for the inside?
https://mciracing.ca/products/blank-15-a8c764aa-c95b-477f-99ca-537e4bd94b58
- TRX-1-3
- Has thanked: 2068 times
- Been thanked: 992 times
Re: Reversed decal question
I have not, but the only thing I can think of is do they react to the paint and shrink or bubble? and you'd wanna make sure they are down really good especially in any contours cuz of the potential for bleeding under with the paint. I've only applied reverse cut vinyl graphics on glass. We did "wet" installs with super dilute soapy water or a water/isopropyl alcohol mix. You can float them on and then press them down/squeegee almost all of the application fluid out from under them. Essentially like applying water slip decals. In this case, if the are water slip, depending on the size and delicateness if them, some light pressure using a Q-tip from the center out might yield favorable results.
- KidAgain
- Business Member
- Has thanked: 513 times
- Been thanked: 431 times
I have used the MCI reverse decals and they work great, of course surface has to be clean and if you get any air bubbles they will show big time if you use dark colors even if painted bright or light colors you can see the bubbles slightly.
But If done correctly they look great and custom. No reaction to Tamiya paint not sure on others.
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Totally off-topic but I have to say I love your new Avatar
Thank you for the input. I purchased the decals and an extra body if it does not work out. I will keep you posted.
Thanks
Thanks
- 1529 Views
Last post by Dr. Robotnik
- 1546 Views
Last post by rc10johnny
- 751 Views
Last post by body snatcher
- 969 Views
Last post by Quikenuff
- 2642 Views
Last post by R Cane
- 21 Replies
- 2156 Views
Last post by railey72
- 2941 Views
Last post by AscotConversion
- 1069 Views
Last post by bearrickster
