In my local club, I've noticed that most of the "pro" vintage RC10 racers mount the battery sideways (with a shorty pack). Apparently that gives better balance than with inline.Pepito wrote: ↑Fri Feb 14, 2020 9:52 am For a runner, you would only really want one battery cup. It should be locate the length of the chassis with one end of the battery going into the Rear bulkhead pocket and the other being held by the battery box.
The two battery cups were used when you had the mechanical speed controller because the servo went into the rear bulkhead pocket.
Pepito wrote: ↑Fri Feb 14, 2020 9:52 am Are you looking to do a complete resto or a runner? That will make a big difference in what you need/want to do with the Buggy.
There were two different CE editions, the 6 gear tranny (A stamp) and the Stealth Tranny (B Stamp). You have the later CE stealth tranny B stamp that was released in 1992.
Even with the stealth tranny, these buggies still came with a mechanical speed control. You have a Futaba ESC, an upgrade to the original speed controller - hence why you only really need one battery cup.
If you are looking to restore your RC10, that's a whole other animal and list.
Let us know if that is the direction you are looking to go.
Good luck!![]()
If you are going to run it, ditch the old ESC, RX and Transmitter an opt for new ones. They are much more efficient. Also, go with a 2S Lipo battery for the buggy. The run time will last at least twice as long as any other NiCad or NiMh and probably be less expensive to keep and maintain in the long run.
Pepito wrote: ↑Mon Feb 17, 2020 12:07 pmIf you are going to run it, ditch the old ESC, RX and Transmitter an opt for new ones. They are much more efficient. Also, go with a 2S Lipo battery for the buggy. The run time will last at least twice as long as any other NiCad or NiMh and probably be less expensive to keep and maintain in the long run.
To answer your question about "worth", the short answer is - it depends.
Politically and policy around this forum, is you don't ask that type of question and we are not supposed to answer it.
Enter the model number on eBay and search the ESC "SOLD" category with the appropriate condition and that is usually a good gauge as to its worth.
Hope all that helps ya!![]()
