R12L Still Competitive?
MotoObscura
Has thanked: 45 times
Been thanked: 65 times
Post by MotoObscura »
I know nothing about pan cars. I'm an offroad guy who dabbles in rubber tire touring cars.
On the surface, it looks like modern pan cars aren't much different than they were 25 years ago
My track wants to start a rubber tire 12th scale class and it has peaked my interest. If I buy an early 90's 12L, added a typical ROAR legal 1S lipo and the spec brushless motor for the class, would I be at a significant disadvantage than those using a more modern chassis, say an RC12R6?
Nick DiVitto My current vintage racing lineup: Associated RC10 B2, RC10 Team Car, Losi XXT, RC10T, XX4, XFactory X5, Schumacher CAT 2000 www.moto-obscura.com My Youtube Channel
matt1ptkn
Has thanked: 80 times
Been thanked: 133 times
Re: R12L Still Competitive?
Post by matt1ptkn »
From my limited experience, the rubber tires are a great equalizer. Plus, if you fit some rear shocks and have some knowledge on tuning said shocks and pan cars in general, you should able to be quite competitive. Good luck if you decide to pull the trigger!
Matt
Hauptmann6
Post by Hauptmann6 »
Buy modern. The early 90s cars have fixed camber and are really hard on front tires. And the performance ceiling is much lower. I say this as a driver of an early 90s RC10L. (Same design, just upsized.)
rraeford
Post by rraeford »
You may have trouble fitting a brushless motor in a 12l. It was packed pretty tight before.
rraeford wrote: Tue Jan 07, 2020 10:06 pm You may have trouble fitting a brushless motor in a 12l. It was packed pretty tight before.
I'm not sure how much is different from a 12L and a 12L3, here's mine with a brushless 17.5T motor installed; full build topic here:
https://www.rc10talk.com/viewtopic.php?f=37&t=35541
The challenge with resto-modding these is far more to do with mounting a modern battery, as the old-school T-bar linking the rear pod gets in the way. The motor was hardly an issue at all. Fabricating a battery holder was where most of the resto-mod work was needed. 8)
rraeford
Post by rraeford »
The rear bulkheads are different starting with the 12LC (12L3 followed). This allows a lot more room and makes the motor installation and wiring easier.
Ahh, that's good to know... I found that there's over a decade separating the first RC12L and 12L3. :oops:
MotoObscura
Very cool, thanks for sharing!
