RC10L - Looking for Parts
- Regular Member
A local track just started up for carpet oval. My old 1991 RC10L needs some exercise. But I want to have some spares on hand. I found a source a few years ago for the T bar, and front wheel upright blocks(not the right word for it, but the block that had the arms that the hubs attached to. Found the part number # 4115
And wheels and tires for the 4 bolt style rear tires and the fronts that used E clips(yeah, it's that old)
Does anyone know where to find them these days?
- Been thanked: 10 times
Re: RC10L - Looking for Parts
as far the wheels go most of the foam wheels go should work BRL
just use different bearing in front wheels
old trailing or in line axles should work
we run the old classics around hear in the winter
you got a part # for what your looking for ?
marty
marty
- Regular Member
8190 is the T bar and 3211 is the front axle carrier.marty slater wrote: ↑Thu Oct 10, 2019 10:10 pm as far the wheels go most of the foam wheels go should work BRL
marty
I don't have the 8400 front end.
https://img2.associatedelectrics.com/pdf/discontinued_items/drawing_10l.pdf
Not totally understanding what you mean about the axles.
who makes decent foam tires these days?
- matt1ptkn
- Has thanked: 80 times
- Been thanked: 133 times
EBay always has parts, though not usually at prices one is hoping to pay.
Most current pan car style wheels/tires should work; you just may need to shim the front wheels if you continue using the e-clip axles. You can even use the current Legend style "spec" tires from RJ Speed if you don't know which foam to start out with. That's what I usually use, but I'm a lazy racer.
Matt
- Regular Member
I found some world GT spec tires/wheels. And most of the parts I needed after much searching. At not a bad price.matt1ptkn wrote: ↑Tue Oct 15, 2019 8:32 am EBay always has parts, though not usually at prices one is hoping to pay.Most current pan car style wheels/tires should work; you just may need to shim the front wheels if you continue using the e-clip axles. You can even use the current Legend style "spec" tires from RJ Speed if you don't know which foam to start out with. That's what I usually use, but I'm a lazy racer.
Do you know what parts I need to convert the front axles to something better than E clips? They are a PITA
- Regular Member
The one other thing I don't know how to search for is tall rear body mounts for GT/oval bodies. And the wide front bumper. Although I may end up just making a new one
- matt1ptkn
For vintage(ish) oval stuff, I often find myself deferring to RJ Speed. https://rjspeed.com/ Prices are reasonable and the parts are readily available. Many LHSs should also carry RJ Speed parts in stock, as the Legends class is quite popular. They have body posts up to 4" long, front threaded axles, steering blocks, etc. As far as my experience goes, vintage par car parts are of a standardized size. There are plenty of other options out there, I just always prefer quick and easy.
As far as bumpers go, I've always cut out my own and custom fit it to whichever body I'm running. I use this type of stuff from McMaster-Carr and have had great results: https://www.mcmaster.com/acrylic/pvc.
Matt
- Regular Member
Thanks for the suggestions all!
I have 90% of what I need and am rebuilding it today. Now I just need to find what parts box I put the speed controller in. Can anyone help with that???? lol
- radioactivity
- Has thanked: 384 times
- Been thanked: 618 times
It will be in the last one
Chuck
Chuck
- Regular Member
Thanks all! I had it at the track today, the electronics were dead so i had to replace the ESC and motor. I put a 13.5 in it due to it being the only one at the hobby shop. Holy crap is it fast even with NMh batteries in it. Turned down the speed as low as I could on the radio and still could barely keep from breaking out. Still handles amazingly as well.
Next project is a 17.5 and lipos.
- Regular Member
One more question, anyone know where to get a replacement chassis? I'm striking out on all the usual places. I want to change to a carbon chassis and add a real servo mount.
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Check with the guru GoMachV on this forum. He has a shop in the marketplace. He might be able to help you out with a chassisHauptmann6 wrote: ↑Sun Dec 01, 2019 9:24 pm One more question, anyone know where to get a replacement chassis? I'm striking out on all the usual places. I want to change to a carbon chassis and add a real servo mount.
- Has thanked: 1129 times
- Been thanked: 3919 times
Thanks Todd, we can definitely do the chassis but im not working with carbon for a while. Not only is is expensive but it’s a pita and messy, weak, and hard on my router. Sorryklavy69 wrote: Check with the guru GoMachV on this forum. He has a shop in the marketplace. He might be able to help you out with a chassis
- Incredible_Serious
- Has thanked: 1737 times
- Been thanked: 1145 times
That's just got to be a euphemism....
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
- 31 Replies
- 5511 Views
Last post by durb69
- 2689 Views
Last post by klavy69
- 2422 Views
Last post by lmw94002
- 1641 Views
Last post by templeofspeed
- 21 Replies
- 2627 Views
Last post by Bent
- 906 Views
Last post by tiger1
- 1004 Views
Last post by Devilbrad
- 3342 Views
Last post by ChisaiKuso
