My 1st 4-10 Legend Build - Need Some Help
After many years, finally was able to start on my 4-10 Legend build. I need some guidance though....
1. I have several MIP SP1 transmissions. I would like to use one for this build. Has anyone successfully utilized a SP1 for a 4-10? It seems I would need to modify the center gear to accept the 4-10 drive shaft....but even then it does not seem like the pin would fit properly. Am I wasting my time? Should I just stick to the Stealth set-up?
2. I am missing the rear idler bearing assy in my kit. However, I was planning on using the bulkhead from the Ten4 setup with their hardware. Anyone have any experience or issues in going this route?
Thanks in advance. I will post some progress pics once I get it going.
- Has thanked: 41 times
- Been thanked: 91 times
Re: My 1st 4-10 Legend Build - Need Some Help
Hi, sounds like a cool project, I would advise against using the sp-1 rear transmission it wouldn’t really be in the spirit of the 4-10 legend.
As far as the belt guide you can use a 0.71” Shock shaft in one of the stealth transmission bolt holes.
It will screw into the motor plate.
I cant remember the exact stack up I used but there is an Edinger alloy shock spacer then a 1/8" shim 1/8 x 5/32" bearing another 1/8" shim and another 1/8 x 5/32" bearing and a standard 1/8" e-clip to hold it together.
Mine is on a ten-4 not a proper legend. The belt may be too tight, if so you can try the smaller 1/8 x 1/4" bearings instead.
If you have any trouble with the stack up let me know I'll take mine apart if necessary.
the MIP trans will have a different ratio than the legend front transmission. So you would have to adjust the pulley ratio, if it's possible. it's probably better to use the stealth trans, because you also would need the idler shaft for the MIP trans for the 4wd conversion which is not easily found. the idlers are not the same and the shaft diamters are different, metric vs english.
I think the ten4 bulkhead should be very close to what you need. i don't have experience with it, but the layout should be very close, since the pulley is driven from the idler in both designs.
Nice catch I hadn't thought of that. The gear ratio is wrong the sp-1 being 2:1 and the stealth 2.25:1jwscab wrote: ↑Mon Oct 07, 2019 3:46 pm the MIP trans will have a different ratio than the legend front transmission. So you would have to adjust the pulley ratio, if it's possible. it's probably better to use the stealth trans, because you also would need the idler shaft for the MIP trans for the 4wd conversion which is not easily found. the idlers are not the same and the shaft diamters are different, metric vs english.
Thanks for the quick guidance. Looks like I will just stick with the stealth transmission. I am hoping that Brian has an additional hardware kit from his Ten4 builds he can sell me for the bulkhead...or maybe someone else has an extra one around.
On a side note, I am also looking for a custom painter for the body....any recommendations?
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
Do you have a complete kit then probably cheaper to go with a Stealth tranny and you can probably find one either here or eBay. If you're missing parts then I have no idea how hard this would be but I wish you luck.
This is all very interesting!
- 3910 Views
Last post by mikea96
- 3372 Views
Last post by Diamond Dave
- 61 Replies
- 6246 Views
Last post by Goatless
- 1387 Views
Last post by RichieRich
- 80 Replies
- 10076 Views
Last post by R Cane
- 2676 Views
Last post by JK Racing
- 2564 Views
Last post by slotcarrod
- 1615 Views
Last post by MOmo
Users browsing this forum: DotNetDotCom.org [Bot] and 9 guests
