Hello,
I’ve been searching all over the internet (to no avail) to find out if the YZ-10 bulkheads/caps (and differentials since i’m on the topic) are the same as the original YR-4 ?
I did come to a conclusion (could be wrong) that they are compatible, but i’m trying to understand if they are exactly the same or not.
Any help is greatly appreciated, thanks.
Help needed with YZ-10 vs YR-4 Bulkheads
Re: Help needed with YZ-10 vs YR-4 Bulkheads
for the 870c/yz10, as far as I am aware, the bulkheads are indeed almost identical, except one is magnesium, or a possible aluminum upgrade, and one was made of black plastic. I believe interchangeable except there might be a tweak or minor trims of the plastic parts to work. diffs are the same and i have seen people use the black caps on the magnesium bulkheads. later yz10's have some more differences, including a different front end assembly.
- Been thanked: 4 times
Thanks for speedy response, I've been following a few YR-4s on ebay and they look to have the magnesium bulkheads all around. Not sure if these are OEM on the Oder kits, I'm just looking for a donor car for bulkheads so I can build up my YZ-10. Thanks againjwscab wrote: ↑Wed Sep 18, 2019 1:24 pm for the 870c/yz10, as far as I am aware, the bulkheads are indeed almost identical, except one is magnesium, or a possible aluminum upgrade, and one was made of black plastic. I believe interchangeable except there might be a tweak or minor trims of the plastic parts to work. diffs are the same and i have seen people use the black caps on the magnesium bulkheads. later yz10's have some more differences, including a different front end assembly.
- 1950 Views
Last post by 86NESKid
- 50 Replies
- 16624 Views
Last post by mytimac
- 1919 Views
- 755 Views
Last post by longboardnj
- 1346 Views
Last post by stickboy007
- 3126 Views
- 1669 Views
Last post by highwayracer
- 2410 Views
Last post by twisted
