I was wondering: What is the difference between Stealth # 6564,and Stealth # 6565?
Does anybody know the difference?
Stealth Trans. Different Stock Numbers
- Has thanked: 307 times
- Been thanked: 5 times
- Has thanked: 1130 times
- Been thanked: 3920 times
Re: Stealth Trans. Different Stock Numbers
6565 is the original style case which actually fits and works well lol. It is identified by the 4 individual spacers that go between the trans and the motor plate. Use a 6570 idler. 6564 is a pos that was developed for the rere Worlds car. It has the spacers built in and features a tight gear mesh often causing binding and roughness. Cannot be used with the 6570 idler as there are no places in the case for idler bearings. They go in the 6569 idler gear itself.
Wow,you are the Man,GoMachV ! I thank you very much!GoMachV wrote: ↑Sat Aug 17, 2019 9:32 pm 6565 is the original style case which actually fits and works well lol. It is identified by the 4 individual spacers that go between the trans and the motor plate. Use a 6570 idler. 6564 is a pos that was developed for the rere Worlds car. It has the spacers built in and features a tight gear mesh often causing binding and roughness. Cannot be used with the 6570 idler as there are no places in the case for idler bearings. They go in the 6569 idler gear itself.
- 817 Views
Last post by bluewormx
- 1298 Views
Last post by longboardnj
- 115 Replies
- 15214 Views
Last post by woodall01
- 1943 Views
Last post by badhoopty
- 921 Views
Last post by MarkyDents
- 24 Replies
- 4755 Views
Last post by mrlexan
- 25 Replies
- 3025 Views
Last post by chophead69
- 2411 Views
Last post by lmw94002
Users browsing this forum: Ahrefs [Bot] and 3 guests
