Team Car Spur Washers
80sRunner
Has thanked: 4 times
Post by 80sRunner »
I'm putting back together a team car and I came across this: there is a hardened washer at the left, and what appears to be an aluminum (shock washer), grooved washer to the right.
How would you proceed? I'm looking at Team Associated No. 6594.
Additionally, flat washer side toward the bearing?
Thanks!
ChisaiKuso
Has thanked: 5 times
Been thanked: 27 times
Re: Team Car Spur Washers
Post by ChisaiKuso »
That is too funny. I came across the exact same thing while restoring an RC10. You are on the right track with the #6594 thrust bearing washer kit.
Something clever goes here...
Has thanked: 1105 times
Been thanked: 3807 times
As Chris said that is the right kit. You can then choose to use the brass that it will come with (updated, good for runners) or keep your thrust bearing (for an era correct build)
Users browsing this forum: User avatarGoMachV, User avatarMotoObscura, No User AvatarTbot [Bot] and 7 guests
