Shock Ball ends.
General info, Q&A.
guitronics
Has thanked: 307 times
Shock Ball ends.
Post by guitronics »
Hi: I have been trying to get "Shock ends" or "Ball ends" for my builds.I need a bunch of them..RC 10.I can't find any online...sold out.I'm talking about the Threaded part of the Shock Shaft that screws into the mount,and the ball inside.
I found some Dubro mounts on Tower's site,they are 4-40,and have the mounting ball...anyone ever used those?
Thanks, Mike
Re: Shock Ball ends.
The originals are going to be hard to find now as the source is drying up. You can use alternative ones from associated and run a nut behind the ball to approximate the built in spacer on the original. The ones you mentioned will also work with the same spacing.
guitronics
Thanks a bunch! I really appreciate the help.
Mike
Users browsing this forum: No User AvatarMojeek [Bot], No User AvatarTbot [Bot] and 5 guests
