Shock Body Sizes
Shock Body Sizes
Trying to sort through some Associated shock bodies and wanted to know where you measure them to determine the part number. e.g. 0.71" is that the overall length, bore depth or the diameter where the spring sits?
- XLR8
- Has thanked: 1684 times
- Been thanked: 1180 times
Re: Shock Body Sizes
I think "0.71" refers to the stroke and not to the length of any single part. That said, each shock assembly will require different length bodies and shafts so perhaps someone here can provide a chart showing the various body lengths. Also, the seal packs in early shocks loaded from the outside while later ones loaded from inside and this might affect overall length of the body for a given stroke -- the difference shouldn't be much if any.
- XLR8
Actually, I have a couple early bottom load bodies close at hand and here are overall dimensions:
0.56" #6455 - 1.08"
1.32" #6452 - 1.85"
0.56" #6455 - 1.08"
1.32" #6452 - 1.85"
- 936 Views
Last post by shane
- 455 Views
Last post by aeiou
- 972 Views
Last post by dimebag d.
- 594 Views
Last post by jaro
- 823 Views
Last post by GeekSpeed
- 1740 Views
Last post by mark in wi
- 7829 Views
Last post by Bimdapogs
- 1145 Views
Users browsing this forum: DotNetDotCom.org [Bot] and 3 guests
