WOIN RC10 "new" build...
NomadRacer
Has thanked: 81 times
Been thanked: 79 times
Post by NomadRacer »
Starting another build, almost have all the parts to get started.
All that's needed are a few more parts; rear arm mounts (ordered), shock end caps and collars (ordered), turnbuckles, and misc. parts.
Bum on Direct Deposit
NomadRacer
Re: WOIN RC10 "new" build...
Motor- 17.5T Brushless Arrowmax, chosen for the gold accent anodizing :wink:
NomadRacer
Starting at the front; I have Factory Works carbon fiber front shock tower for big bore shocks, AE Steering bell cranks, Avid Bearings, AE, dyed black front arm mounts and Factory Works button head load bearing washers.
I'll be using stainless steel hardware everywhere I can.
XLR8
Has thanked: 1684 times
Been thanked: 1180 times
Post by XLR8 »
Always looking forward to your builds Nomad. You are a master RC craftsman to be sure.
Ummm, also, not to be pushy but are you planning to wrap up some of your other builds anytime soon? I recall that a couple of them still need painted bodies. Not being pushy -- just asking... :D
radioactivity
Has thanked: 384 times
Been thanked: 618 times
Post by radioactivity »
Nomad
I don't really know why but after checking a pic of the motor the first thing that struck me was "BumbleBee"ish.
Nice choice.
Chuck
NomadRacer
While I was installing the steering bell cranks I found the shims for the bottom of the bell crank bushing nuts to be a little bit out of wack. One shim being thicker than the other. I fixed this with some T.O.P. Racing 1mm thick aluminum shims for pan car rear axles. These parts are a bit hard to find now a days.
XLR8- The weather is getting just about right for some outdoor painting. :wink:
radioactivity
XLR8 wrote: Mon Mar 25, 2019 2:54 pm Always looking forward to your builds Nomad. You are a master RC craftsman to be sure.
Me too
Inquiring minds need to know :) :) :)
Chuck
NomadRacer
radioactivity wrote: Mon Mar 25, 2019 2:57 pm Nomad
Nice choice.
Chuck
Yes Chuck, the motor is quite the "looker" :wink:
NomadRacer
Got a bit more done on the build. Servo is a Savox 1258TG with Exotek servo horn and Avid servo mounts. The servo mounting washers were made by me. :mrgreen: The arms are World's wide track with 30* caster block carriers. 24mm titanium screws used with Avid B6 Shock standoffs and Lunsford hinge pins. Black ball studs are used for the front camber links.I will be switching those out for some AE Ti Nitride ones (on order) later on.
XLR8
Post by XLR8 »
The black/gold theme you have going looks very nice Nomad.
What are the black ball studs you mentioned -- are they dimensionally similar to the standard kit studs?
NomadRacer
XLR8 wrote: Mon Apr 01, 2019 11:48 am The black/gold theme you have going looks very nice Nomad.
Yes, they are dimensional to kit studs... .20 and .300" long with 4-40 threads. They are broached ends though, (2mm). I'm pretty sure I got them as a set from the B44 series. Can't call the kit for sure right now.
I'm digging the black/gold myself. :wink:
XLR8
Post by XLR8 »
Thanks Nomad. While they're probably not appropriate for a restoration project, I think they'd be fine for everything else. I find the broached ones a little easier to install and tighten. I wasn't aware they'd fit vintage style ball cups.
NomadRacer
I have the Ti Nitride ball studs now, along with Lunsford Titanium Wide Front Axles (RC10GT). Next, bust out the RIT Dyemore Graphite and dye the rear bulkhead and the Stealth transmission cases.
KidAgain
Business Member
Has thanked: 513 times
Been thanked: 431 times
Post by KidAgain »
Wow looks great man, I have a gold anodized servo arm that matches the gold on the servo any interest ill send it to you.
also would you happen to have a part number for the GT axle from lunsford?
Jake
NomadRacer
KidAgain wrote: Mon Apr 08, 2019 8:53 am Wow looks great man, I have a gold anodized servo arm that matches the gold on the servo any interest ill send it to you.
Jake
The part number for the Titanium wide front axles are LNS7048. They are on the Lunsford web site now :wink:
I'd be interested in your gold servo arm :mrgreen:
