Nikko Dictator and Nikko F10 Rhino / Thunderbolt
The place for all things Toy Grade.
mark
Has thanked: 14 times
Been thanked: 90 times
Post by mark »
Just wanted to share some pictures of my Nikko's
Nikko Dictator I and II
Cleaned up the gear boxes and added bearings
Nikko F10 Thunderbolt and Rhino
I converted the blue to hobby grade including 2.4 radio gear inside the original Nikko radio. I also converted the front end over from the Traxxas Cat, it bolts right on and provides a wider front track.
Some bench pics.
Grass Hopper wheels and tires on the white Nikko F10 Rhino along oil filled shocks.
Dadio
Has thanked: 2759 times
Been thanked: 2250 times
Re: Nikko Dictator and Nikko F10 Rhino / Thunderbolt
Post by Dadio »
I've got to admit I like the Dictator , very near a hobby grade car in a lot of ways , there's a guy on RCGROUPS who has done a double BL and 2.4g conversion to one , it looked a lot of fun !
Here's a link to the thread by Nowinaminuite on rcgroups for the double BL one [url]https://www.rcgroups.com/forums/showthread.php?2856659-Nikko-Dictator-One-pretty-One-ugly&highlight=Nikko+dictator/url]
korreka
Post by korreka »
More things about Nikko Thunderbolt
Tires for Nikko Thunderbolt / Bison / Rhino:
http://reparar-cochesrc.blogspot.com/2016/11/neumaticos-de-nikko-thunderbolt-bison.html
The rim is 50mm in diameter (1.9 "); the original tire is hard to get.
One option is to put a crawler tire with foam insert. The tire is bonded with contact adhesive.
The tire diameter is 100mm, much larger than 85mm of the original tire diameter.
korreka
Post by korreka »
Another option is to put the Tamiya Hornet rear tire. This has an internal hole of 36mm (1.5 "). If you cut with a cutter the inner edge of the tire (very careful !!), the operation of mounting it on the rim is easier:
korreka
Post by korreka »
There is also the option to change the wheel. The Nikko car wheel adapter copied from Tamiya.
The Tamiya rear wheel (Hornet, Frog) can be attached to the Nikko adapter and also, the Nikko Thunderbolt wheel fits well to the Tamiya adapter. The Traxxas (The Cat) adapter is similar but I don't know how it fits well on Nikko or Tamiya wheels.
Image Image
If we want to use a wheel with a 12 mm hexagon, we have to use a long adapter that has a inner screw to fix the 5mm shaft of Nikko car.
The picture shows the adaptor fixed to the shaft and a wheel with 0mm offset.
korreka
Post by korreka »
The Nikko Thunderbolt was sold with 380 and 540 motors. The 540 motor version was a 35T or 45T motor: 12600 rpm at 7.4V and 1.3A no load current y the car has full proportional control electronics.
I have tried to put a 27T motor (Johnson "silvercan" motor of Tamiya) of 18,000 rpm and 1.6A no load current. The original electronics do not overheat.
The original electronics have a "H-bridge" of bipolar transistors: 2SA1129 (pnp) and 2SC2654 (npn). These transistors have a maximum current Ic = 7A and drive a peak of 15A.
The collector-emitter saturation voltage of these transistors is Vce-sat = 0.3V at Ic = 3A or
Vce-sat = 0.6V at Ic = 5A, so the motor is powered between 0.6 or 1.2V less than the battery voltage.
The motor speed is lower than the same car with ESC (electronic speed controller) of Mosfet transistors.
In spanish lang. in http://reparar-cochesrc.blogspot.com/2020/01/cambio-de-motor-nikko-thunderbolt.html
chak
Post by chak »
Hello friends, I am new to this site and I am from France. I have a nikko thunderbolt rc. Sorry for the language I am using a translator. I need to change the battery connection plug but I don't know where the black and red wire solder points are on the electronic board. Do you have a photo of the electronic plate or a drawing?
thank you
korreka
Post by korreka »
chak wrote: Mon Nov 16, 2020 4:52 am Hello friends, I am new to this site and I am from France. I have a nikko thunderbolt rc. Sorry for the language I am using a translator. I need to change the battery connection plug but I don't know where the black and red wire solder points are on the electronic board. Do you have a photo of the electronic plate or a drawing?
thank you
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
Is this similar to the Red Arrow?
last5liter
Been thanked: 7 times
Post by last5liter »
Has anyone ever heard or seen of reproduction decals for the Nikko rhino?
korreka
Post by korreka »
Red Arrow (Radcon Wild Fox)
http://reparar-cochesrc.blogspot.com/2018/02/revision-de-radconm-wildfox-radio-shack.html
RC10th wrote: Tue Dec 08, 2020 3:27 am Is this similar to the Red Arrow?
korreka
Post by korreka »
https://www.retromodelisme.com/document_page/126/nikko-rhino-f10-nikko.html
last5liter wrote: Tue Dec 08, 2020 9:16 am Has anyone ever heard or seen of reproduction decals for the Nikko rhino?
lee540
Post by lee540 »
Whilst clearing the loft I found this Rhino F10 which was given to me back in 1987.
Unfortunately, one of the rear dampers got broken and it was put into storage. I'd love to get it going again, I will create another thread to seek spares or alternatives.
Return to “Nikko / Tyco / Toy Grade Forum”
