Original tires for rc10gt 3 piece wheels
- coxbros1
- Has thanked: 2758 times
- Been thanked: 2407 times
Hi, i am restoring an original rc10gt (black tub), i have the 3 piece wheels and need tires. What fits properly and is close to original.
Thanks in advance!
Thanks in advance!
- radioactivity
- Has thanked: 384 times
- Been thanked: 618 times
Re: Original tires for rc10gt 3 piece wheels
Hey there D&D!
No expert on trucks but are your wheels 3 piece like original RC10?
Chuck
Chuck
- Attachments
- Wheels.JPG (19.97 KiB) Viewed 1226 times
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Are you going to run it? Newer tires are softer and won't hold the bead on your 3 pc wheels so it makes a difference.
Are you going full boxart or just looking for something to work?
There are some new oop rear fuzzies on ebay from proline for a decent price or a set of used ones for half that.
If you do a search for 'vintage proline tires' it will bring you up to a few options.
- coxbros1
I may run it a little, no bashing, no dirt, thanks for info.
Yes the look similar to those rc10 wheels, just bigger
- radioactivity
Hey there
Do you know the wheel's diameter?
Will make a difference on tire choice.
Chuck
Chuck
- Been thanked: 81 times
Hello . This may help . The GT black tub came with solid rims 7842 front and 7802 if you have 1/4 axles and 7803 for 3/16 axles .
https://www.teamassociated.com/pdf/cars_and_trucks/RC10GT/Team/tubGT_manual1b.pdf
Also any 2.2 truck tire will work on the solid rims . Just pick your tread pattern for front and rear . The 3 piece rims need a harder tire like # 7870 and # 7820 both are long discontinued .
- 1989 Views
Last post by JosephS
- 1235 Views
- 1296 Views
Last post by Group B
- 1730 Views
Last post by carloco8
- 2136 Views
Last post by atarit3
- 1019 Views
- 996 Views
Last post by MotoObscura
- 558 Views
Last post by SnoopMaxx
