My sons car (or mine?) t4.3
Forum rules
- ELF-BMX
- Has thanked: 31 times
- Been thanked: 50 times
My sons runner not quite finished, waiting on the electronics, he accidentally put positive in the neg slot and blew it up,whoops. I think i want to put a 10t body on it, motor is just mock to set shocks
- NomadRacer
- Has thanked: 81 times
- Been thanked: 79 times
Re: My sons car (or mine?) t4.3
Nice build, your son will have a lot of fun with it, or you!
Bum on Direct Deposit
- ELF-BMX
Thank you! I dont think you can see but i just put fresh cvs’s on there, it had cvd’s but i dont like them theres no retainer clip on them (cva’s) so if the set screw comes loose its game over, the pin comes loose and destroys your hub.NomadRacer wrote: ↑Tue Nov 27, 2018 6:23 am Nice build, your son will have a lot of fun with it, or you!
cva the clip can still move, or come off. some people would put a drop of ca on it. or both the cva and cvd you can put shrink tubing over it. shrink it.
- ELF-BMX
I like the shrink tube idea, when i had the non-clip ones the sst screw came out,so the pin worked its way out an destroyed house aluminum hub, so i put glue on the pin and it workeda lil until i need to service it then it was a pain to dig out glue, so i like the dhrink wrap idea just cut it off when need to, thanks
All tips are welcome
- ELF-BMX
A little update: added hobbywing esc quicrun 10bl160 (sensored)
Smc 5700mah 135amp 90c lipo stick
Hobbywing Quicrun 3650 8.5t sensored motor
Just need tx/rx now
Just need tx/rx now
- Has thanked: 35 times
- Been thanked: 10 times
That Hobbywing combo is what I had mind also. Curious what you think of it!
- ELF-BMX
I haven’t used esc yetbroodenburg wrote: ↑Tue Dec 04, 2018 4:04 am That Hobbywing combo is what I had mind also. Curious what you think of it!
I love the motor, but it was with the now discontinued xerun sct pro 120amp esc before and i loved the combo. I tried replacing but they dontsell if and the new version of that esc is to much money so i went with the cheaper quicrun series, but they say the motor is supposed to work better with the new esc so i will let you know soon i run it
? For you i just hooked up esc out of box and the fan worked then i unpluged it then pluged it back in and it no longer works, any ideas y?
I dont use a fan in my T3 so ....... Tried an other fan to check if it's that or the ESC?
- 2078 Views
Last post by JosephS
- 987 Views
Last post by RC Chick
- 791 Views
Last post by soniccj5
- 881 Views
Last post by blown5.0
- 478 Views
- 833 Views
Last post by Erich Reichert
- 1401 Views
Last post by shodog
- 1588 Views
Last post by rctenracer
