gold on black heavy metal rc10 worlds
discgolfer72
Has thanked: 21 times
Been thanked: 36 times
Post by discgolfer72 »
been wanting to get some alloy dhawk parts to build a rc10 for some time now
I bit the bullet and went ahead in bought the full set
over the past couple of days ive started the other parts also
so far everything going into it is brand new parts except the stealth tranny I bought , but most of it will be new as well , after I rebuild it and shove it in the alloy tranny case
anyone used the mono shock setup what size shock do I use
also anyone have some links to current replacement shocks that will work with the rear (and hopefully the front)
would like them blue or gold alloy
Associated 6192 Rc10 Accessories
Team KNK Stainless Hardware Kit
dhawk full alloy parts set gold
beater rc10 stealth trans
lundsford worlds car titanium pin set
rere worlds chassis
rere worlds chassis
rere worlds chassis
3/16 cvd set
3/16 cvd set
3/16 cvd set
front mono shock tower
NomadRacer
Has thanked: 81 times
Been thanked: 79 times
Re: gold on black heavy metal rc10 worlds
Post by NomadRacer »
Nice! I have the rear bulkhead and it's spot on.
Bum on Direct Deposit
discgolfer72
NomadRacer wrote: Fri Sep 07, 2018 6:09 am Nice! I have the rear bulkhead and it's spot on.
I hope everything is to spec (esp the screw holes)
parts have started to trickle in
tranny, hinge pins, and hardware showed up today
tracking shows dhawk kit just passed customs (weeeeee)
was going to order some shocks , but might just use these new old duratrax front truck shocks in the rear, and a 10gt front shock for the front mono (with the extra weight want to make sure they are nice and stiff so I get minimal chassis slap )
tranny seems ok its pretty gunky and the diff is a bit tight but should do the trick
discgolfer72
new batch of parts showed up today and the build is starting lol
schwing this is going to look great , probably will drive like a brick with wheels but meh lol
I did notice the chassis is anodized pretty light on this reere chassis its kinda molted , dark in some spots lighter in others
discgolfer72
did a bit more work today before I head off to the shop
what bearings do I use in the rear with the 3/16 axles the kit I picked up says it comes with 3/16 but I got it today and there are no flanged ones for the rear that are 3/16
NomadRacer
I believe you need 3/16" x 3/8" plain bearings (no flange). Don't take that as "gospel", check/verify. :wink:
shodog
Been thanked: 91 times
Post by shodog »
Looks great so far. I like the contrast between the gold and black. I'd di8tch that gold nose plate in favor of a black one.
discgolfer72
shodog wrote: Wed Sep 12, 2018 5:25 pm Looks great so far. I like the contrast between the gold and black. I'd di8tch that gold nose plate in favor of a black one.
that was the plan but this build is getting expensive fast lol , and I had the gold plate on hand
it has some small scratches on the bottom so I'm probably going to rhino line the bottom in black
still need to buy ball studs and turn buckles
then all the electronics
Been thanked: 3917 times
Lunsford still sells both the classic and punisher style turnbuckles direct. I will be distributing them as well in a couple weeks, but you can call or email barb at Lunsford and she can hook you up.
discgolfer72
GoMachV wrote: Wed Sep 12, 2018 5:36 pm Lunsford still sells both the classic and punisher style turnbuckles direct. I will be distributing them as well in a couple weeks, but you can call or email barb at Lunsford and she can hook you up.
thanks
i dug in my parts bins and found 3 that should be old punisher turnbuckles (lets hope i can find the rest)
if i cant find the set i will for sure contact them direct
not much more done tonight
dug in my bins and found a good set of light alloy front axles (quick session with some 800 grit and they look new )
got them installed
and then made some nose brace tubes out of some tube stock i had lying around
dug into the big oh box of tires i got from here
https://www.rc10talk.com/viewtopic.php?f=39&t=43400
and found a really nice set with no /little use that will fit nice
my store is closed tomorrow so i have my fingers crossed that my lhs has a set of bearings for the rear hubs , and front rims . then its just a waiting game for the other parts
discgolfer72
ok crap shocks came in today
still no mono shock mount (seller said he is shipping today due to flu )
but big problem the wheels I have hit the shock springs
what do you all thik lol are these to much (to big lol)
discgolfer72
or I did order these shocks also (internal spring) I was going to use them for the front mono
but I can use the tires and rims I have in the rear if I use them
im torn I like the blue beefy ones a lot
but the black one actually go with the build and are pretty sleek
any thoughts
NomadRacer
I like those black shocks... Desert Lizard? Where'd you get them?
discgolfer72
NomadRacer wrote: Thu Sep 13, 2018 8:23 pm I like those black shocks... Desert Lizard? Where'd you get them?
https://www.ebay.com/itm/Yeah-Racing-90mm-Desert-Lizard-Two-Stage-Internal-Spring-Shock-DDL-090BK/142869118524?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
they are pretty cool looking
but they are a bit odd ( im sure with the spring kit included you can tune them)
they are made for crawlers and will be great for the front mono setup
they have a spring on top and under the piston inside the shock body (long one on top,short under)
but were to stiff for the rear
I ended up finding some alloy spacers and did get the blue shocks to work without rubbing the wheels or hitting the rear bulkhead
NomadRacer
Sorry, I couldn't do more than a thank you for the reply last night. I was experiencing technical difficulty with the internet last night. :?
I'm going to look into those black shocks. Maybe with some tuning they can be made to work.
Your black/gold is looking very nice. I'd have to give up the cash and put a black nose plate on it. Maybe have Ramen Noodles for a few days and get one! :lol:
Users browsing this forum: No User AvatarAhrefs [Bot], No User AvatarYandex [Bot] and 5 guests
