Question - ProCat replacement parts
Cawanga
Post by Cawanga »
Hi all!
I've just rediscovered my old ProCat in the attic. It's been (obviously) quite a few years and I would really like to race it with again. Unfortunately I've got a broken front pivot bracket (t156 Pivot bracket front - 15 degree rake) and I also lack tension bands for the "crashback".
Erm... I would probably need to replace the belts as well.
I've been in contact with Schumacher Racing and they lack replacement parts for the ProCat and have thus removed it from the vintage list. Can anyone give me some help with suggesting other parts that might do the trick? From what i see the CAT XLS look pretty much the same. Some of you seem to build your vintage cars using parts from different models, what parts would be the best one for me to order? (pivot bracket front, drive belts, long drive belt & tension bands).
I'll try to provide o few pics as well.
Best wishes
Cawanga
Retro rc
Has thanked: 665 times
Been thanked: 473 times
Re: Question - ProCat replacement parts
Post by Retro rc »
Hi there,
Yes the xls re re parts will fit, the part numbers you need are
7195 front pivot set
7217 crashback orings
7174 main drive belt
7175 rear drive belts
Good luck with the rebuild
Adrian
Cawanga
Post by Cawanga »
Thank you Adrian, I'm very grateful!
Return to “Schumacher Forum”
