Question about RC10B2
mmar141
Post by mmar141 »
hello,
I'm new to RC buggies and happened across an Associated RC10B2 with a broken front upper. Since I'm assuming they dont make the parts anymore, where would be a good place to find replacement parts? Also, which parts are interchangeable with other versions?
Been thanked: 3917 times
Re: Question about RC10B2
Front upper? Do you mean the 9130 front top plate? That’s one of the single most difficult items to buy if you need to keep it a legit B2. The B3 piece is easy to locate and bolts right up. Just depends if you want functional or proper for a restoration. The B3 has holes for a sway bar and run about $7 shipped on eBay
mmar141
Post by mmar141 »
Oops. I meant to say front A arms. I believe the part is 9105.
Ahh that I can’t say. I’m sure someone will chime in tho
Tamlok
Been thanked: 7 times
Post by Tamlok »
If you are going to run it, converting it to a B3 is your best option, as those parts are available. It will take more parts than just the arms, see the conversion sheets below. Grab the manuals from Associated's website which will give you all the proper part numbers.
https://www.teamassociated.com/cars_and_trucks/RC10B2/Team/manuals_setups/
https://www.teamassociated.com/cars_and_trucks/RC10B3/Team/manuals_setups/
If you want to keep it original B2, as GoMachV stated, those parts are hard to find. Good luck!
XLR8
Has thanked: 1684 times
Been thanked: 1180 times
Post by XLR8 »
FWIW, I had to replace a broken front B2 arm a couple years ago. I paid a ridiculous price for them so the B2 was ultimately retired to the shelf and I run a B3 now.
With the improvements AE has made, I think the B3 handles better anyway.
If you're just interested in getting your car back on the track quickly, you can fit B3 arms without doing any mods. I did this for my B2 while I waited for the correct replacement arms to arrive. I think I needed to lengthen the steering links a little as the B3 arms are longer.
XLR8
Post by XLR8 »
Here's something to consider. These cars were made to be run. However, I seemed to recall that, since the B2 had one of the shortest production runs of any RC10, it is considered to be one of the rarest. You may want to exercise some caution if you choose to continue running your car. :D
ChisaiKuso
Has thanked: 5 times
Been thanked: 27 times
Post by ChisaiKuso »
XLR8 wrote: Sat Aug 18, 2018 11:19 am Here's something to consider. These cars were made to be run. However, I seemed to recall that, since the B2 had one of the shortest production runs of any RC10, it is considered to be one of the rarest. You may want to exercise some caution if you choose to continue running your car. :D
You are correct. Another factor contributing to the rarity of B2s is that a lot of them were converted to B3s.
Something clever goes here...
mmar141
Post by mmar141 »
That's some good advice. Thank you! I'll look to convert it to the B3.
Users browsing this forum: No User AvatarAhrefs [Bot], No User AvatarYandex [Bot] and 5 guests
