What is this?
rcehitaja
What is this?
Post by rcehitaja »
Does anyone know what is this?
Seller made that pic, but now bushings are replaced and its almost clean.
I bough it very cheap and is it worth of restoration?
Is it vintage anyway?
clinehobbies
Re: What is this?
Post by clinehobbies »
Tamiya stadium blitzer or bettle blitzer not really vintage.
Have a nice day! :)
rcehitaja
Re: What is this?
Post by rcehitaja »
Thanks, but can you tell manufacturing year of it ?
Im worried about the gears. I think i cant find them here in Estonia :?
Has thanked: 1749 times
Been thanked: 1149 times
Re: What is this?
rcehitaja wrote:Thanks, but can you tell manufacturing year of it ?
That will be Tamiya, matey.... let me check the TamiyaClub website for the year. If not available in Estonia, I'm sure someone here or on TamiyaClub.com will be able to source you some...
Re: What is this?
I really need to read what others write sometimes....
The chassis is chared with the Stadium Blitzer, Blitzer Beetle, and Stadium Thunder (although some plastic on the latter is red)... Bear Hawk buggy shares the chassis as well, but has red shocks and no tall body mounts.
These are relatively recently out of production, and are a relatively entry-level vehicle... so there should be plenty of parts available.
Stadium Blitzer and Blitzer Beetle have online manuals listed on TamiyaClub, so that would be a good place to start!
Hope that post was more helpful.... :oops:
rcehitaja
Re: What is this?
Post by rcehitaja »
Now it`s quite good. I have to paint on the body not in, because its impossible to get the paint off.
But i found one new model. Kyosho TRACKER. Its in mint condition, but it doesn`t have box.
I got it from second hand shop for 100kroons/10 dollars and it had manual and transmitter.
Is it some kind of rarity? Manufacturing year is ~1993?
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Re: What is this?
Post by Mr. ED »
I think the tracker is like a big-wheel version of the kyosho Ultima. Relatively easy to find parts for.
Isn't that a gas car actually, sorry no time to look it up now
rcehitaja
Re: What is this?
Post by rcehitaja »
Its electric. And its different from kyosho ultima.
Only problem is that the tires have cracks on their sides.
Mr. ED
Re: What is this?
Post by Mr. ED »
your're right it is electric nad I'm right alos: it is based on the ultima:
http://www.thehobbystore.com/kyoc0216.html
You can see the outside of the gearbox and the rear arms and uprights: all original ultima prts. Beside that: a cheap plastic chassis and shock mounts, cheap shocks, cheap.... wel you get the picture.
The one picture is a '2', the only difference as far as I know: the tracker has a yellow body and other decals.
Any standard truck tires will fit and will be an improvement over the standard tractor tread.
can look good if well done like this one: http://koti.mbnet.fi/~oju/rc/Tracker2eng.html
Return to “Tamiya Forum”
