Hitch in my Stealth
- Has thanked: 7 times
- Been thanked: 4 times
Hitch in my Stealth
I just rebuilt my stealth transmission with new bearings and a t4 top shaft and fresh grease. I figured it would be nice and smooth, but now it has a nice hitch in it. This is when I have it screwed to the motor plate, but no clutch on it. I'll be tearing it down again to check, but I'm looking for suggestions. I used old ring and balls but sanded down the rings with 1000 grit... I wonder if I had a flat surface somewhere?
Re: Hitch in my Stealth
Turns out it was some grit stuck in the root of a few of the teeth... I tried the top gear and it was about the same. Looked at the idler gear and it still had junk in it. Apparently I didn't clean it as well I thought I did...
Any tips on cleaning the gears? I was think tooth brush, but that might not be enough.
- 31 Replies
- 6232 Views
- 735 Views
Last post by burnsmonkey
- 1392 Views
Last post by LTO_Dave
- 1340 Views
Last post by wait a minute
- 64 Replies
- 8670 Views
Last post by askbob
- 1079 Views
Last post by SteveK
- 24 Replies
- 2391 Views
Last post by msedsp
- 1032 Views
Last post by Seabass
Users browsing this forum: Nmore14 and 1 guest
