Stealth Idler Gear removal
- Has thanked: 7 times
- Been thanked: 4 times
Does anyone have any tips for removing the idler gear bearings from my RC10 stealth transmission? They are the last thing to remove in my tear down and Im stuck. Tried a good smack on the table and they didn't budge.
- Has thanked: 1129 times
- Been thanked: 3917 times
Re: Stealth Idler Gear removal
Insert the idler or a top shaft and just give it a slight twist to lock it against the shaft as you gently pull. They will come out
If you wanted to get really tricky you could do like the 1:1 guys and pack grease in the hole and press a shaft in, making it hydrolock out but that’s a ton of messy work
That was my first thought... But your first suggestion was much cleaner Thanks!
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
+1 for the top shaft. Insert and cock the topshaft slightly, then pull.
- 1033 Views
Last post by joel45acp
- 1757 Views
Last post by superfly
- 1398 Views
Last post by templeofspeed
- 815 Views
Last post by fr3ak317
- 106 Views
Last post by carloco8
- 1300 Views
Last post by SteveK
- 1337 Views
Last post by JosephS
- 948 Views
Last post by adam lancia
