is there a thread on here that has all these bodies? i guess i didnt realize there were so many options.jwscab wrote: ↑Wed Jun 20, 2018 8:21 pm Hahaha that's a loaded question. Some guys love the protech. Some guys love the mirage, some even like the viper. Then you have the entire aftermarket. And of course the protech 2 and sidewinder.
Of the associated bodies, I like the mirage and protech 2. The original protech is growing on me with the right cut and slamming it low.
I also really like the jammin jumper.
RC10 B-Stamp Resurrection.
- sbednara
- Has thanked: 13 times
Re: RC10 B-Stamp Resurrection.
RC10 Championship Edition
Tekin Rebel ESC
Fantom Motor
Tekin Rebel ESC
Fantom Motor
- XLR8
- Has thanked: 1055 times
- Been thanked: 783 times
Turbo Mirage vs original Protech body. I really like both of these.
- YakkityYak
- Has thanked: 5 times
Its getting there! Just ordered the last bits to get it put together. Also ordered a body and wing, plus some stencils, but that's a surprise!
Losi - Mint-T
Associated - RC10 (x2)
- NomadRacer
- Has thanked: 83 times
- Been thanked: 77 times
There you go man. Who would have thought there was a prize like that under the paint!
Bum on Direct Deposit
- YakkityYak
Yeah! Theres still a few bits of paint, but i figured I'd get around to that on the second rebuild.NomadRacer wrote: ↑Thu Jun 21, 2018 6:20 am There you go man. Who would have thought there was a prize like that under the paint!
In the mail coming there is,
• Set of new White ballcups
• Proline Octigrab rears
• Used A&L Trailing Arm Kit (C1 Style)
• Proline Diamond Fronts
• Body Mount Kit,
• Dogbone Springs and spacers (they went flying)
• Body, Wing, and masks.
• That pesky 1.3mm Allen so I can try and properly rebuild the shocks.
Speaking of rebuilding shocks, is there a kit anymore out there to do them? I've looked, but I've only found $30 vintage kits, would it just be better to get a set of newer shocks?
Losi - Mint-T
- sbednara
Fwiw. I’m doing same, complete rebuild of the shocks. I just bought some o-rings and that’s it. Unless something is damaged I believe that’s all that’s needed.
Tekin Rebel ESC
Fantom Motor
Tekin Rebel ESC
Fantom Motor
- YakkityYak
Well hotdog! I've only got about 10,000 orings sitting around, I'm set!
Losi - Mint-T
- YakkityYak
Here's a little hint of where im going with this build...
Losi - Mint-T
- YakkityYak
I finally got most of my parts!
...Just to lose a single eclip. And that one eclip halts all progress. And I'm out of R/C budget soooo, onto the shelf it goes.
Oh and one of the grubscrews for the front shocks is stripped, so I have to tear apart this arm, and order some more shock pins.
Jeez...This thing Is quickly turning into a money pit.
On the second hand, I'm kinda rethinking using these brand new ProLine diamonds and octigrabs.
Are the e clips the 1/8th size?
Losi - Mint-T
- Lonestar
- Has thanked: 626 times
- Been thanked: 166 times
yes - eclips are 1/8th indeed: Team Associated 6299 E Clips, 1/8" (12) - i'd send you one but by the time it crosses the ocean you'd have refilled the bank account anywayYakkityYak wrote: ↑Sun Jun 24, 2018 8:11 pm I finally got most of my parts!
yes - all restoration projects end up costing a LOT more than planned... always
- NomadRacer
@YakkityYak send me a PM about some e-clips, I could help you out.
- YakkityYak
I did finally find an e clip. Got most of it together. Then realized I need new turnbuckles/threaded rod for the front. These wide arms sure look like they will help though.
Got my Novak 410M5 today. Can this thing handle a 2s Lipo? If not I'll throw in a modified Chinese ESC.
Losi - Mint-T
- Lonestar
Yes, it can "handle" a lipo to some extent. The issue will be the motor+lipo - the M5 was a sport speedo which would punch above his weight at the time for sure. so you could run a mild-to-hot mod. With a lipo battery that can pump out a lot of current very easily, it can become easy to toast a M5 if you go too hot a motor. In any case I wouldn't run it for more than 7-8 minutes at a time. remember these speedoes were designed for batteries that could only run your car for 5mn anyway...YakkityYak wrote: ↑Mon Jun 25, 2018 6:14 pm Got my Novak 410M5 today. Can this thing handle a 2s Lipo? If not I'll throw in a modified Chinese ESC.
I run my TRX1 on an M5 with a 15 turn mill + lipo and it survived... I actually cooked the motor last time instead
- YakkityYak
In that case I'll use my Chinese ESC, and use the M5 for something else. Thanks for the advice.
Losi - Mint-T
- YakkityYak
So heres an update. Got it together for the most part.
M5
Anyone here good with soldering small bits? I'd love to convert it to one of those all black receiver wires, along with resoldering the main wires.
Lightspeed Motor. Anyone have info on these?
Made a solid rod to take out some slop from the steering assembly. It works pretty good.
M5
Losi - Mint-T
- 546 Views
Last post by LurkingCAT
- 3960 Views
Last post by knucklebuster
- 29 Replies
- 4974 Views
Last post by SMOKE-DOG
- 2519 Views
Last post by SoCalSnakeEyes
- 667 Views
Last post by radioactivity
- 91 Views
Last post by morrisey0
- 86 Replies
- 7749 Views
Last post by Blacktiger355
- 23 Replies
- 1610 Views
Last post by RC4X4
Users browsing this forum: Ahrefs [Bot], Trendiction [Bot] and 6 guests
