4B1and 4B2 Compatibly?
- Regular Member
I was wondering if I could upgrade the front of my 4B1 to use the 4B2 front end? Has anyone else done that?
- Has thanked: 1134 times
- Been thanked: 3934 times
- Incredible_Serious
- Has thanked: 1749 times
- Been thanked: 1149 times
Re: 4B1and 4B2 Compatibly?
Well, this is a 2x4..... which is like a 4x2... am I close?
- RC10th
- Has thanked: 55 times
- Been thanked: 1586 times
Wow Mr. I'm impressed by your internationalism.
I'm guessing he might mean B4.1 and B4.2
Just for that, you get a 2x4 too.... Oprah-style....
- RC10th
I'm fine with that
There are no 2x4's in Australia, only 90x45's
- Regular Member
Rough crowd. I’ll get my crosscut saw out and fix this.
Sorry
I have a RC104B.1 Factory Team. I was wondering if the 4B.2 front end would be compatible.
Sorry for the sloppy original post
Sorry
If it makes you feel better, our 2x4’s haven’t measured 2x4 since around the 50’s
Totally makes sense now. I was racking my brain trying to figure out what you had. I have to bow out now though, as the B4 is a bit new for my knowledge baseChetPunisher wrote: ↑Thu May 24, 2018 9:16 pm Rough crowd. I’ll get my crosscut saw out and fix this.
Sorry
- LowClassCC
- Has thanked: 108 times
- Been thanked: 171 times
Most of the parts from the Team Associated RC10B4 line up including the B4, B4.1, B4.2, and B4.3 are interchangeable. Most of the front end only had small changes. The biggest imo of the front was the spindle / axle setup. Earlier buggies had bearings in the front wheels where the last ones has bearings in the spindle and used a 12mm hex on the axle for the wheels to bolt to.ChetPunisher wrote: ↑Thu May 24, 2018 9:16 pm I have a RC104B.1 Factory Team. I was wondering if the 4B.2 front end would be compatible.
You wouldn't need to change everything. Just the axle's, spindle's, c hub's, and the hardware. The shocks, tower, arms, and bulkhead wouldn't need to be swapped as there are minor differences if any.
And your front wheels....LowClassCC wrote: ↑Thu May 24, 2018 11:22 pmYou wouldn't need to change everything. Just the axle's, spindle's, c hub's, and the hardware. The shocks, tower, arms, and bulkhead wouldn't need to be swapped as there are minor differences if any.ChetPunisher wrote: ↑Thu May 24, 2018 9:16 pm I have a RC104B.1 Factory Team. I was wondering if the 4B.2 front end would be compatible.
- Regular Member
