Factory Works C2 Carbon Fiber
- Has thanked: 792 times
- Been thanked: 2270 times
Re: Factory Works C2 Carbon Fiber
Nomad nailed it, those are for cutting the contour as well as the drill jig
Factory Works website
- NomadRacer
- Has thanked: 83 times
- Been thanked: 77 times
The pic doesn't show but I get where your coming from
Bum on Direct Deposit
- NomadRacer
The body and ball cups arrived alive! Big thanks to Sabula Tech for the crisply pulled body. The outlines are nice, better than most lexan bodies I've bought in the last year. I'm picky about that stuff like that, having worked on HO and 1/24 scale lexan molds. I have already busted out my red Sharpie pen and started marking out a plan for initial cuts.
Updated Information on the SAXOX servo: I bought it direct from SAVOX USA. I'm on the mailing list from them (sign up, it's free) and took advantage of a 15 percent off coupon they had sent me via email. That deal resulted in a cost of 52 bucks and change, free shipping included.
The last two black editions I bought had long, thick sheathed servo lead wires. I replaced them with black TQ Wire leads. This time, it came with a short 3"/75mm lead already installed. Maybe, buying direct, I got the newest version?
Pretty disappointed in associated once again. Friday I got my 7th set of these that came with the wrong shims and pins. Don replied to my request for replacements:NomadRacer wrote: ↑Thu Apr 12, 2018 12:50 pm The CVA kit will cause you to scratch you head a bit. It comes with shims and roll pin for the 3/16" CVA's! Come on Associated, get your act together. So, get you some 1/4" shims and a pack of ASC6375 roll pins and you'll be good to go.
- NomadRacer
No worries on the shims as long as the correct roll pin is in the package.
For shims, I use 0.015" thick from CRC and 0.005" from the AE RC12R5.2.
- NomadRacer
I'm getting the steering servo mounted this afternoon...
- NomadRacer
Tires! I got some Tires!
The steering servo has been mounted and the buggy re-assembled. I dyed the battery cup last night, simmered in RIT Dyemore and left to soak overnight. The Shapeways/CPD white parts take to dye very quickly.
I have some electronics inbound; ESC, RX, and a brushless motor. I'll probably be able to get into doing some installation this coming weekend.
- mk-Zero
- Business Member
- Has thanked: 4 times
- Been thanked: 19 times
- XLR8
- Has thanked: 1051 times
- Been thanked: 780 times
I agree, it does look amazing. Curious to hear your feedback on those tires; on what surfaces do they work best, etc.
- Has thanked: 10 times
- Been thanked: 445 times
those proline hawgs work great on lots of different surfaces. stone, grass, dirt, asphalt, etc. They are fairly tall compared to dedicated clay or carpet tires but they work well otherwise.
- NomadRacer
You know, I was looking at just that this morning! There are some open holes that could be used
- 22 Replies
- 3381 Views
Last post by XLR8
- 977 Views
Last post by templeofspeed
- 562 Views
Last post by PBR Allstar
- 1343 Views
Last post by iPearl
- 453 Views
Last post by toolman72
- 1326 Views
Last post by aeiou
- 3097 Views
Last post by fordtransman
- 1265 Views
Last post by trkneller
Users browsing this forum: Bing [Bot] and 6 guests
