Cleaning vintage R/C gearbox and diffs?
Kaare-65
Post by Kaare-65 »
Wondering what is the best (and safest) way to clean vintage R/C gearbox and Diffs.
I have done a lot of searching and see that a lot of people use Naptha, I am just wondering if it is safe to use on a vintage gearbox, diffs, and "gears"?
If it helps......Of course I am talking about an RC10 as well as Kyosho Optima and Optima mid parts
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Re: Cleaning vintage R/C gearbox and diffs?
Post by Lonestar »
Not sure if the best way... but I use warm water, dish soap and an old toothbrush first.
Then kitchen towel and motor spray (which is a trychlo-base, so try to use gloves as much as possible) for greasy residues :)
Naptha is pretty bad, I wouldn't use it at all. Maybe for nitro.
Use simple green full strength or diluted, on any plastic or steel parts. Aluminum parts can sometimes shadow stain so use caution there. I drop the parts in and let soak 24 hrs or however long you forget. Follow up with a scrubbing with a tooth brush and that will clean them.up nicely. Alternatively and as a second bath, regular dish soap and warm water works awesome(again with the tooth brush)
mikea96
Has thanked: 660 times
Been thanked: 878 times
Post by mikea96 »
I second the simple green soak then warm water and dish soap.
Kaare-65
Post by Kaare-65 »
Which type of Simple Green? They now have the original recipe, along with industrial cleaner & degreaser, clean building, heavy duty, crystal, and I think one or two more.
I am guessing the original, All Purpose, Stuff.
Thanks for the info. Simple question, but I'm glad I asked before taking others advice.
mikea96
Post by mikea96 »
I use the original myself.
TRX-1-3
Has thanked: 2068 times
Been thanked: 992 times
Post by TRX-1-3 »
QD electronics cleaner and also Mass Air Flow Sensor cleaner (spray cans) will degrease quickly without harming plastics (greasy diff components).
Yeah the original green stuff is what is use.
WD-40 and a toothbrush, then a rinse in hot water and Dawn dish soap.
Kaare-65
Post by Kaare-65 »
Thanks for all the answers. I have been using dawn, just picked up some simple green, but still need to get WD-40.....that stuff was always a sin to have around when I grew up.
Also have a bunch of bottles of Hydrogen Peroxide for the RC10's white part.
LTO_Dave
Has thanked: 52 times
Been thanked: 287 times
Post by LTO_Dave »
Spray Nine cleaner works really well for grease on plastics. I just used some and a toothbrush on a set of Yokomo diff pulleys.
Dawn Power Dissolver was the most amazing cleaner I've ever used but it's been long discontinued.
RC10th
Been thanked: 1548 times
Post by RC10th »
Simple green is good as it conditions both rubber and plastic, it doesn't contain any harsh solvents to dry out plastic or rubber.
Users browsing this forum: No User AvatarGoogle Feedfetcher and 2 guests
