Adam Rayls' killer RC10B2 racer
littleVETTE
Has thanked: 6 times
Been thanked: 9 times
Post by littleVETTE »
Adam's b2 is your normal buggy with a few modern upgrades to accommodate today's racing scene. Nothing trick done to the transmission, suspension, or chassis. Pretty much bone stock out of the box. No carbon chassis pieces either, other than the front carbon shock tower. Pretty impressive, considering he still races it.
The Chassis is standard length composite. And the reason for not using any carbon pieces on his buggy? Adam: "..that old stuff was stiffer than the newer plastics they use [today]. The carbon was really stiff". His lipo fit right in with no modifications. Still uses the foam pads to adjust the battery's position for tuning. An associated battery thumb screw is used to mount his battery hold down. All his electronics are reedy and sanwa.
Front end is all stock. He does have a carbon shock tower mounted. Arms are composite material. Carriers are 30 degrees. Front axles are the more modern extended units. Hinge pins are stock and turnbuckles are titanium. He uses associated low friction B4 ball cups. Up on the shock tower he uses associated blue aluminum shock mounts for his V2 small bore shocks. He's not a fan of the big bore stuff on older buggies. Length of the shocks and shafts are stock, as well as the pistons. Bell crank's ackerman position is stock. He does use ball bearings on the right hand servo saver. Top plate is the stock composite unit.
Rear suspension is also stock. Including the rear shock tower. Mounted on the shock tower are the same associated aluminum shock mounts and V2 small bore shocks. Stock lengths, and stock pistons. He's using the 3 degree toe - 3 anti-squat rear suspension mounts, along with 0 degree rear hubs. For the axles he used the stock b2 CVD shiny bones but opted for the b4 axles. So he could run the wheel spacer. Out back the associated b4 low friction ball cups are used as well. Stock hinge pins and associated blue titanium turnbuckles.
Transmission is bone stock with a b4/t4 top shaft. For the vonats he used a slipper eliminator. He's currently using the b4/t4 slipper clutch. Gear cover is stock. The transmission brace is the stock composite unit.
Wheels up front are b4 wheels and rears are kit stock (same as the re-re rc10 worlds).
Body is stock and the wing is from jconcepts - high clearance wing.
sandkil
Has thanked: 782 times
Been thanked: 584 times
Re: Adam Rayls' killer RC10B2 racer
Post by sandkil »
That is awesome!
What a lovely car.
Lonestar
Has thanked: 623 times
Been thanked: 170 times
Post by Lonestar »
Nice B2 that seems to fare pretty well in that vintage race where pics were taken (cannot see exactly what's on the trophy plates - but this says "vintage" despite the "modern racing scene" in the opening paragraph). Cool paint scheme!
two Q's:
- what is the source of this article?
- is Adam a member here?
littleVETTE
Lonestar wrote: Wed Feb 21, 2018 4:16 am Nice B2 that seems to fare pretty well in that vintage race where pics were taken (cannot see exactly what's on the trophy plates - but this says "vintage" despite the "modern racing scene in the opening paragraph). Cool paint scheme!
two Q's:
LMAO
Lonestar
Post by Lonestar »
littleVETTE wrote: Wed Feb 21, 2018 4:51 am
two Q's:
LMAO
Well - can you educate my sorry non-American self, please? Because this
https://www.google.com/search?q=adam+rayls+b2+associated&rlz=1C1GGRV_en__762CH762&oq=adam+rayls&aqs=chrome.0.69i59l2j69i57j69i64j69i61l2.2514j0j7&sourceid=chrome&ie=UTF-8
doesn't get me anywhere :)
Thanks!
Paul
Has thanked: 33 times
Been thanked: 1178 times
The plaques are from the 2017 Vonats.
Kinda doubt he's a member on here.
Lonestar
Post by Lonestar »
scr8p wrote: Wed Feb 21, 2018 7:28 am The plaques are from the 2017 Vonats.
Thanks :) Am I missing something obvious that can warrant the LMAO?
Been thanked: 496 times
Probably the way you've worded you response about 'vintage vs modern'. The track is pretty modern and the car and cars were running some really good laps. So 'vintage' is kinda not as vintage as it appears. I Guess? I dunno.
littleVette, would you happen to have any of the shock setup info? As also, what tires was he running? What reedy electronics are they?
The car, and the amains in general, were pretty awesome to watch, I was hanging at the end of the back straightaway at the bank, and those guys were flyin'.
DaveM
Has thanked: 727 times
Been thanked: 26 times
Post by DaveM »
littleVETTE
setup sheet directly from adam:
Asso_man!
Has thanked: 40 times
Been thanked: 81 times
Post by Asso_man! »
What is the black box next to the receiver? Gyro, 2.4 Ghz module or LiPo cut-off?
Come and visit the stable
Lonestar
Post by Lonestar »
Thanks for sharing the source.
Asso_man! wrote: Thu Feb 22, 2018 5:11 am What is the black box next to the receiver? Gyro, 2.4 Ghz module or LiPo cut-off?
Looks like a shrink-wrapped transponder to me :)
RC10th
Has thanked: 50 times
Been thanked: 1490 times
Post by RC10th »
What is the truck , 10T?
Lonestar
Post by Lonestar »
RC10th wrote: Thu Feb 22, 2018 6:07 am What is the truck , 10T?
(watch out, you're THIS close from geting an "LMAO" back...)
DaveM
Post by DaveM »
1st Adam Rayls – Team Associated RC10T2
I would be interested in seeing a topless shot!
Users browsing this forum: No User AvatarBing [Bot], No User AvatarGoogle Adsense [Bot] and 9 guests
