Cougars salad
eugine
Cougars salad
Post by eugine »
Hi guys.
The menu for coming weeks is a Cougars salad
First you must retrieve all the ingredients, a early cougar with some touches of Topcat and a second one in kit.
After you shall very well clean it and cook it in boiled water some minutes. Be careful not too long !
After you dry it
Then you serve it layed on a big wooden platform with some sand paper sheets and a bowl of water !
When it is done you spend a lot of time paper-sanding then polishing it
After you have polished it until you can see your tired face in, you scratch the surface to have the same "brushed" finish as the original one
then for the dessert you shall assemble it...
To be continued ...
Re: Cougars salad
Polishing always gets my attention...that chassis tub is looking fantastic! I have mostly Kyosho cars, with the exception of a nice little AE RC12L3, but if there's one car I'd like to build, it's one of these Schumachers. Looking forward to the rest of your resto!
eugine
Re: Cougars salad
Post by eugine »
Thank you Coelacanth.
Tha advantage with aluminum is you can "repair" most of track damages. Not all because deep scratches are remaining but most of them :)
Kyoshos and RC12 are great cars also!
eugine
Re: Cougars salad
Post by eugine »
Hi guys.
I give you a status on the progress of my cooking :)
The nose gear assembled
The transmission case with teethed belt inside.
This tranny was one the best, silenth smooth ands with very high efficiency. We were looking at the last electrons in the packs at this time :)
Rear suspension and tranny installed. It starts to look like the pure racer it was :)
To come: renewal of the shocks
See ya
XLR8
Has thanked: 1684 times
Been thanked: 1180 times
Re: Cougars salad
Post by XLR8 »
You do nice work sir.
I've experience only with the 4wd Schumacher CAT. Looking at your builds, it's interesting to see just how many parts are shared between the 2 and 4wd cars.
Anyway, your cars are coming along nicely. :mrgreen:
eugine
Re: Cougars salad
Post by eugine »
XLR8 wrote: Sat Feb 03, 2018 6:13 pm You do nice work sir.
Thank you. 4WD CATs are great machines :)
eugine
Re: Cougars salad
Post by eugine »
Hello.
The shelfer is finished. I had troubles to instal wheel ball bearings on the shaft because the inner ring was a little to small.
I installed them with a tool made of a long screw, nut and washer to allow a smooth slippery.
I had no authorized additionnal budget by my home financial minister for a new wing :mrgreen: so I repaired the original one the best I could, hidding scratches under yellow and red adhesive fims.
As it is finished now I am really convinced that it is a Topcat converted with Cougar front suspension plus a Cougar body decorated with remaining stickers from the original Topcat kit.
That's also why it came with the original Topcat manual.
On the few I did, it was the longest and most difficult build I did for the moment.
But maybe for that I am very hapy with it. :D
The runner is stopped for the moment because I don't want to install the original rear shock tower but I want to do one in aluminum or graphite.
It will allow also to install a wing support strongest than the original.
I will continue this post in the future
See ya guys
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Re: Cougars salad
Post by Lonestar »
Très joli - very nice and inspiring here too ;)
eugine
Re: Cougars salad
Post by eugine »
Lonestar wrote: Sun Feb 18, 2018 6:26 am Très joli - very nice and inspiring here too ;)
Thank you neigbour ;)
XLR8
Re: Cougars salad
Post by XLR8 »
Your completed shelfer is awesome! If I hadn't read your entire post, I would have assumed the car was NIB. Very clean and carefully assembled. Nice!
I also like to build two of every car I collect; one shelfer and one runner.
eugine
Re: Cougars salad
Post by eugine »
XLR8 wrote: Sun Feb 18, 2018 10:48 pm Your completed shelfer is awesome! If I hadn't read your entire post, I would have assumed the car was NIB. Very clean and carefully assembled. Nice!
Thanks mate. No it isn't nib unfortunately. You could see that very easly with the car in your hands.
The pictures are always more gorgeous than the hard reality :)
I will soon change the front plate for a new one but the lower faces of the arms are still witnesses of its previous life.
Retro rc
Has thanked: 665 times
Been thanked: 473 times
Re: Cougars salad
Post by Retro rc »
eugine wrote: Wed Feb 21, 2018 5:08 pm
Front arms are still around if you look for them :wink:.
But what I want to know is where you found the front rib tyres
eugine
Re: Cougars salad
Post by eugine »
Retro rc wrote: Fri May 04, 2018 12:24 am
You mean they are available in the Schumacher site ?
I will have a look but I didn't find them during the rebuild.
I bought the tires from a guy here. They are vintage not new.
Retro rc
Re: Cougars salad
Post by Retro rc »
Hi Eugene,
yes Schumacher still has them in stock part number u774 and there are also many online stores that have them in stock still to. You can also use part number u2330 as the arms are the same but the hubs are different as they take a twin bearing setup. The hardest cougar arms to find are the cougar 2 arms part number u847 and those front ribs I can't find anywhere nip
Return to “Schumacher Forum”
