Servo Savers?
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
Re: Servo Savers?
If you can consistently drive 5 minutes around a track without crashing or clipping a pipe then you probably don't need a servo saver, otherwise you should still run a quality servo saver.
- XLR8
- Has thanked: 1684 times
- Been thanked: 1180 times
Re: Servo Savers?
I've always used a saver. It not only will spare the servo gears but it will act as a shock-absorber preventing damage to other steering components and maybe even prevent a popped ball cup which could cost a win. It's cheap insurance.
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Re: Servo Savers?
Racing or bashing?
Bashing => SS mandatory.
If racing, what category, what are the racing conditions and how well can you drive?
Re: Servo Savers?
Yea I still need a SS then lol, I’m definitely too rusty to go without. I’ve been using a Tamiya SS since the 90s. Any suggestion on other brands? I bought this HR one because it looked so sweet but it is way to big to use on the RC-10...it won’t lay flat!
- XLR8
- RC10th
Re: Servo Savers?
Ditch the Tamiya for a Kimbrough saver.
- Lonestar
Re: Servo Savers?
Kimbrough all the way
If racing onroad, the xray super stiff is good
- Has thanked: 9 times
- Been thanked: 9 times
Re: Servo Savers?
On my race buggy, I run an aluminum servo arm and aluminum bellcranks... no servo saver. Metal gear servo of course. I've had no issues, but I don't really crash much, and typically race on a fairly small track.
Re: Servo Savers?
Yea I've noticed the pros never use them, I guess if they do strip one (I've heard even metal gear servos have plastic gears in them) they probably get new ones for free...
- mk-Zero
- Business Member
- Has thanked: 4 times
- Been thanked: 21 times
Re: Servo Savers?
I never use them, even on my relatively heavy 4wd 1:10 buggies, with high quality metal gear servos.
Of course, now that I said that, I will explode a servo at the track tonight
Re: Servo Savers?
For me personally, I've saved money by buying a simple arm rather than a heavy duty servo saver, but I'm sure damage to a metal gear servo is still a possibility. The last time I've had to replace servo gears was in about 1996, and they were plastic, so I may be more willing than most to take some chances at this point.
I know servo savers used to be the norm, but less so as time as passed, and definitely don't seem to be used much at this point. What time period are you referring to when you mentioned you used them as a pro?
Re: Servo Savers?
Personnaly I strated to drive a B6 on a bumpy astro track with tons of grip.
All what I need to brake a servo
I ran one year with a metal geared Servo (Savox) without any problems with a plastic arm.
And I crashed a lot.
I bet the plastic will worn around the servo shaft before to brake the gears.
This year I will put a metal one
- 567 Views
- 946 Views
Last post by wrighla
- 906 Views
Last post by SmallScaleSmitty
- 1773 Views
Last post by surgetek
- 635 Views
Last post by slvrback
- 1062 Views
- 30 Replies
- 6818 Views
Last post by LowClassCC
- 1101 Views
Last post by Johnboy72
