Best battery RC-10 B6D?
Hey guys, what would you suggest as the best Lipo battery for the B6D? Does it have to be a shorty pack? I’m sure this has been asked before, but there might be newer batteries available now. Thanks in advance.
- Has thanked: 9 times
- Been thanked: 9 times
Re: Best battery RC-10 B6D?
You can't really go wrong with SMC. Good product, good price, and more customer service than you'll find with the ones pictured. A lot of guys are using batteries from the smaller companies like Fantom, Motiv, etc. with great results too. That being said, the ones you posted are also solid choices, but probably wouldn't be #1 for me at the moment.
- NomadRacer
- Has thanked: 81 times
- Been thanked: 79 times
You can get the bullets from nearly any online rc shop. I get a lot of my parts and supplies from amain.com
Shop around for the best price.
I'm assuming you don't have a local hobby shop... I don't so online is the only place for me.
Bum on Direct Deposit
Hmm what mm size do these Lipos take? Are these the right size?
https://www.amazon.com/gp/product/B00EZKW1T4/ref=as_li_ss_tl?ie=UTF8&linkCode=sl1&tag=rchelicopterf-20&linkId=c6bb77d25ccf210cbcc5c9f94d55f926
It looks like they range from 2-8mm, so confusing...
- NomadRacer
Typically, they are 4mm or 5mm. You will need to check the specs on your battery.
I'm not pimping the manufacturer, this is the brand/type I use...
https://tqwire.com/product-category/rc-products/4mm-bullet-plugs/
https://tqwire.com/product-category/rc-products/5mm-bullet-plugs/
Why would they make batteries with 4mm and 5mm, that means if I solder 4mm bullets onto my ESC I can’t use batteries that take 5mm bullets.
- Has thanked: 1105 times
- Been thanked: 3807 times
My batteries with 5mm bullets came with 4mm inserts to adapt them. Not sure if this is common but you might look and see
Weird question. Would a 5000mah NiMH Have the same run time as a 5000mah Lipo?
- XLR8
- Has thanked: 1664 times
- Been thanked: 1171 times
Oddly enough, I've found that they don't. I have timed my SC 10 with both batteries and found that the nimh ran about 8 minutes less. Both batteries are roughly the same age and neither are what I would consider high-end.
- 2017 Views
Last post by SoloGraphix
- 5109 Views
Last post by mk-Zero
- 1242 Views
Last post by Diamond Dave
- 3688 Views
Last post by Lonestar
- 1482 Views
Last post by badhoopty
- 857 Views
Last post by Winger
- 532 Views
Last post by m2fit4u2
- 793 Views
Last post by motomike
Amazon [Bot],
Google Adsense [Bot] and 6 guests
