Finally getting round to putting the body and wing on.
Back in the day - did people trim the wing tubes? Mine seem to be sticking up too much above the shock tower.
I have a vague recollection that back in the day I cut off 5 mm (1/4 inch)?
Cheers
Wing Tubes query
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Wing Tubes query
early tubes were long iirc, and later (CE era) they shortened up the holes in the bulkhead to put the inner camber link below it. If your using early tubes and a later bulkhead im pretty sure they will be a bit long
- ChisaiKuso
- Has thanked: 5 times
- Been thanked: 27 times
This is correct. Don't cut those longer tubes since someone else may need them for an original bulkhead.
Something clever goes here...
- 1118 Views
Last post by rctenracer
- 2469 Views
Last post by License2iLL
- 1564 Views
Last post by Chewbacca
- 1870 Views
Last post by TomiS
- 1570 Views
Last post by CNA75
- 1584 Views
Last post by GJW
- 1174 Views
Last post by hugger19
- 1560 Views
Last post by justinspeed79
Users browsing this forum: Tbot [Bot] and 6 guests
