Twice as Lethal 6x4 Truck Conversion
- Has thanked: 1129 times
- Been thanked: 3919 times
I can't let Daryl have all the fun
From the outside it's a throwback to his truck but this one runs dual Lethal Weapons with off the shelf components instead of the hand built chain drive single motor setup. I also went with buggy components and truck offset wheels. I think the offset wheels fit the trailing arm era better (although the Lethal Weapons are then too new, and shocks are far too modern!)
The plastics were dyed with some Lightspeed Neon Yellow dye.
A few of the aluminum pieces were anodized blue, including the motor plates, trailing arm pivots and slipper hubs which I haven't installed yet. They will match the shocks.
- TRX-1-3
- Has thanked: 2066 times
- Been thanked: 992 times
Re: Twice as Lethal 6x4 Truck Conversion
That's rad, dude. Is that just an optical illusion with the rear shock angles? The rears look a little more stood up.
Yeah just an illusion- they are identical except 5" further back
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
kool!
what electronics you gonna use? especially with the 2 motors/esc?
as far as the lethal weapons being "too new" I'm not thinkin its gonna take away too much from the build
I found a pair of identical stock motors a while back and they would be ok for it, but I might buy a couple cheap modern brushed motors. I have a Titan that was needing a place to call home
- klavy69
- Moderator
yeah, your traxxas rustler/srt conversion
- Has thanked: 19 times
- Been thanked: 26 times
That's definitely on the flipside! Wow! What body are you going to use? Something from MadMax with rivets and faded natural steel is what I first envisioned when I saw six wheels.
Back in the day, Daryl spliced two together. I'm not certain which direction I'll go yet but splicing is always an option
- mk-Zero
- Business Member
- Has thanked: 4 times
- Been thanked: 21 times
- ChisaiKuso
- Has thanked: 5 times
- Been thanked: 27 times
I like where this is going...
Something clever goes here...
- mk-Zero
- Business Member
That thing is begging for a Ten4 conversion!
Would that make it a Ten6?
- klavy69
- Moderator
Parma(?) made a school bus body that would rock that thing
Oh that would be cool. And yellow
Wish someone would pop some puller bodies. I could start cutting out the Dually chassis again
- 22 Replies
- 2709 Views
Last post by aoH
- 1062 Views
Last post by Phin
- 2683 Views
Last post by THEYTOOKMYTHUMB
- 1960 Views
Last post by RC10Eh
- 1037 Views
Last post by illshou
- 19 Replies
- 3608 Views
Last post by vintage AE
- 808 Views
Last post by klavy69
- 1191 Views
Last post by Synergy
