Help with JrxT parts
- Regular Member
I recently got my JrxT back up and running after sitting in a box for the last 27 years. Still running my Novak T4, Trinity Monster Horsepower World Champion stock motor, and circa 1985 charger. I ended up buying some new Racer's Edge 1800 ma NiCad's, Futaba S3004 servo, and a Futaba 3PRKA transmitter. The old 2 stick 75mhz radio setup wasn't cutting it.....too much interference.
Anyhow, I just broke one of my front camber tie rods and was hoping somebody might be able to help me source some new ones. Also, my rear shocks are in sad shape. I have the 5-link rear suspension setup. The shock collars are being held in place with zip ties and one of the rear shock cups is held together by Gorilla glue. Was hoping someone could help me find new shock collars and rear shock cups that fit the 5-link setup. I wouldn't be opposed to converting away from the 5 link setup so that I could run modern shocks that don't break or leak.
Any help here would be greatly appreciated!
-Tim
-Tim
- LosiXXkid
Re: Help with JrxT parts
eBay usually has what you're looking for.....Krameraxeman wrote: ↑Tue Mar 14, 2017 11:42 pm I recently got my JrxT back up and running after sitting in a box for the last 27 years. Still running my Novak T4, Trinity Monster Horsepower World Champion stock motor, and circa 1985 charger. I ended up buying some new Racer's Edge 1800 ma NiCad's, Futaba S3004 servo, and a Futaba 3PRKA transmitter. The old 2 stick 75mhz radio setup wasn't cutting it.....too much interference.
-Tim
http://www.ebay.co.uk/itm/Losi-A5023-Shock-Spring-Clamps-Cups-/262625275894?hash=item3d25afaff6:g:-moAAOSw2gxYtIrl
- matt1ptkn
- Has thanked: 80 times
- Been thanked: 133 times
Also don't forget to check out www.oldrc.com. Lots of vintage Losi parts there. The camber links are standard 4-40 turnbuckles and can be replaced with anything similar if you can't/don't want to find the actual Losi parts. Also, the shocks are rebuildable. Find a set of the A-5015 cartridges and your shocks will be good as new, assuming that the shafts are in good shape. Also, new spring collars are easily found online. Part A-5023 will get you what you need or you can usually find used shocks/parts/part lots on eBay. You can also swap to different shocks with the 5-link. You'd just need to swap the lower shock mount to your new shocks. If you want to swap to the rear H-arm setup, it is very simple. You'll just need a set of the H-arms and hinge pins/spacers or the H-arm conversion kit. I have a few Jrx-Ts, a couple with the 5 link. They are a blast. Welcome to the forum!
Matt
- Has thanked: 33 times
- Been thanked: 260 times
Sabula Tech has what you need for the lower spring mount.
http://sabulatech.com/storefront/index.php?id_product=2831&controller=product
Front camber turnbuckle
http://sabulatech.com/storefront/index.php?id_product=2822&controller=product
Kyosho, JRX-2, Gold Tub Fan
- Regular Member
Thanks guys! I found sabula and ordered up some tie rods, 3D printed 5-link spring cups, and a new gear cover! Didn't think to check ebay in the UK. Those clamps linked are exactly what I need! Really appreciate the info!
- 20 Replies
- 2531 Views
Last post by Lizardking
- 24 Replies
- 2542 Views
Last post by richard.bratton
- 1435 Views
Last post by RC4X4
- 25 Replies
- 4917 Views
Last post by Lavigna
- 1047 Views
Last post by GJW
- 1496 Views
Last post by KV78
- 1877 Views
Last post by howsyouraspen
- 1503 Views
Last post by JK Racing
