RE-RE OPtima FIVE-SPOKE WHEEL 43MM fit original car?
Mr_Procrastination
Post by Mr_Procrastination »
HGI,
As per title, after some info about compatibility on the re-re wheels and tires with original parts?
Thanks
Re: RE-RE OPtima FIVE-SPOKE WHEEL 43MM fit original car?
A better question might be: Does the re-re Optima use the tapered axles and 12mm hex hubs with tapered holes to friction-fit onto the axles?
I don't know for sure but I thought the re-re uses straight axles and 12mm hexes with grub screws, from the looks of it. I'm sure someone else will have a more accurate answer. The size of the wheels shouldn't matter.
DennisM
Has thanked: 30 times
Been thanked: 62 times
Post by DennisM »
You can use the re-release wheels (12mm hex) on the original Optima
Gone fishing
Return to “Kyosho Forum”
