RC10T Wins 2016 Reedy Outdoor?
- RC10th
- Has thanked: 38 times
- Been thanked: 971 times
Re: RC10T Wins 2016 Reedy Outdoor?
Flip outs are bad ass! That's what I used to run at our track. Awesome for hard packed surfaces that are dusty. A bit more squirmy then other tires though.
- Attachments
- file-20.jpg (39.46 KiB) Viewed 1650 times
- Has thanked: 28 times
- Been thanked: 947 times
- RC10th
You can use the later dish wheels like these if your not too worried about the old school look.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNYT8&P=ML
Yeah those were the ones I was originally looking at but I honestly like the old school dish. There's a few obscure hobby shops I know of that may have some of that stuff left in stock.RC10th wrote:You can use the later dish wheels like these if your not too worried about the old school look.
- RC10th
I know what you mean about the old school dish wheels. I always wonder how long they'll continue to make the white dish wheels before they become discontinued. Every time I place a Tower order I bulk it up with a few pair of rims to get to the cupon code discount.firebird1999us wrote:Yeah those were the ones I was originally looking at but I honestly like the old school dish. There's a few obscure hobby shops I know of that may have some of that stuff left in stock.RC10th wrote:You can use the later dish wheels like these if your not too worried about the old school look.
kinda surprised to see the original bumper / tab on the nose plate, even with a smooth hand and good driving, it would get tweaked on jump faces and get the front end all wonky.... any word on seeing this beast uncovered??
- Has thanked: 750 times
- Been thanked: 26 times
Sweet,
Thanks for that.
I see he is running the stock bell-cranks.
If there was going to be a time to announce the re-release of the 10T it would be now.
Thanks for that.
- Has thanked: 795 times
- Been thanked: 2277 times
Just saw that! Pretty awesome! I'm gonna copy the pages just to make sure they don't disappear....
This spotlight is on Chris VanAir's 2016 Reedy Outdoor Off-road championship-winning 17.5 stadium truck. This was a non-vintage class, and he raced against other new models. The truck was a "barn-find" and was purchased new-built, but never used. Chris wanted to keep it as close to its authentic vintage form as possible, so he kept it to its original stock build. Front End
Looking at the front end, you can see it is still in the stock original form. Team Associated threaded shock body #7477 was used for more accurate ride height adjustments, as well as the #6417 gold shock shafts for smooth suspension action. Traxxas® #2362 Ultra Shocks Rebuild Kit O-Rings were used in the shocks. (These O-Rings are similar to current-day X-Rings.) Also GHEA Racing Products #2 Machined Shock Pistons were used with a 32.5wt shock oil and standard blue front truck springs. The ride height of the truck was set at 29mm and no limiters were used in the front shocks.
Electronics Rear End
The rear end of the truck had the same shock treatment as the front end. VanAir used #7483 threaded shock bodies and #6416 gold shock shafts and the same Traxxas® O-Rings and GHEA #2 Machined Shock Pistons, 30wt shock oil, and standard truck silver rear springs with a ride height of 29mm and zero limiters in the shocks. A MIP® #1301 Aluminum CVD Kit was used with #9608B wheel spacers. Inside the transmission were a few hidden vintage secrets: a Thorp machined Delrin® idler gear and one-piece aluminum top shaft to free up the drivetrain, as well as a Custom Works R/C Cars slipper eliminator.
Electronics Inside Front End
Chris used the original stock turnbuckles and ball cups. All other front end parts are original parts from the stock build. Inside Rear End
A newer #6333 battery cup was used, as the original was missing. New mounting holes for the battery cup had to be drilled to account for the new-style LiPo battery. The #6323 RC10 Rear Bulkhead was also used with the outer holes cut off, and Chris drilled new inner holes to match the older Worlds bulkhead. A #6339 battery strap was used to secure the battery. Body and Tires
Fortunately, the truck was purchased with the original body still clear, and this was what VanAir used. Team associated still stocks this body, #6130. A Southern California local racer, Jeremy Lee, of Off The Grid Designs, custom-painted the body. Used were front wheels #7842Y and rear wheels #7802Y. He used JConcepts® Carver tires in blue compound in the front and JConcepts® Flipout tires in green compound in the rear. Stock foam was used in the front tires and Pro-Line® two-stage foam was used in the rears.
Electronics
Chris used a Hobbywing Justock speedo paired with a Reedy #254 17.5 M3 motor and a Reedy #27301 5600mAh Zappers battery. For the servo, he used the #27101 Reedy RT1508 Digital HV Hi-Torque servo. He charged his batteries with his Reedy #27200 1216-C2 Dual AC/DC competition charger at 12a.
Electronics
Factory Works website
- RC10th
Thats a really good effort with the stock bellcranks.
Also a smart use of parts, everything makes sense for stock racing.
Good find on the aluminum CVD's, haven't seen many of them.
That's awesome. Thought I was watching an old vhs. About as stock as you can get while being competitive. I agree on the ball ends too. Very risky.
- jkelm24
- Has thanked: 20 times
- Been thanked: 77 times
Re-re primer... The AE marketing team is checking the market temp on this as we speak!!! *wishful thinking*
AE, put one in a box. I'll buy it. I promise...
- 2668 Views
Last post by alien3t
- 3294 Views
Last post by bully
- 51 Replies
- 5333 Views
- 789 Views
Last post by SofaKing
- 840 Views
Last post by ricerscott
- 482 Views
Last post by soniccj5
- 1502 Views
Last post by Bormac
- 664 Views
Last post by Timmahhh
