old novak motor 2 pin connector name question
tamiyadan
Been thanked: 6 times
Post by tamiyadan »
tamiyadan
Re: old novak motor 2 pin connector name question
Post by tamiyadan »
tamiyadan
Post by tamiyadan »
Been thanked: 3919 times
I use the Amps connectors from Digikey
Male shells: a1411-nd
Female shells: a1410-nd
Male pins: a97887ct-nd
Female pins: a97888ct-nd
tamiyadan
Post by tamiyadan »
tamiyadan
Post by tamiyadan »
AYKBOBCAT
Post by AYKBOBCAT »
Did you put new wires on the esc? Is it tricky? I have a few old ones with very short wires that would need new wires...
tamiyadan
Post by tamiyadan »
AYKBOBCAT
Post by AYKBOBCAT »
Thanks a lot for this. It's helpful.
tamiyadan
Post by tamiyadan »
slotcarrod
Been thanked: 45 times
Post by slotcarrod »
GoMachV wrote:I use the Amps connectors from Digikey
Thank you for finding these, I just sent my order. I also found listed, the black two pin and the nylon 3 pin male and female. Pins should be the same as above:
http://www.digikey.ca/product-search/en?keywords=a112239-nd
http://www.digikey.ca/product-search/en?keywords=a1429-nd&from=home
http://www.digikey.ca/product-search/en/connectors-interconnects/rectangular-connectors-housings/1442556?k=a1400-nd
Yes the 3 pin are what started my search and they are perfect
Users browsing this forum: No User Avatar1911Colt and 7 guests
